Old 03-26-2009, 04:23 PM   #26
justtime520
justtime520's Avatar
Re: over heating
every thing was working fine except for a leak. every thing is good big shroud thats just right. before this mishap it would sit at around 190 to 200 driving and at idle with no probs water pumps turning justfine.
justtime520 is offline   Reply With Quote
Old 03-26-2009, 04:25 PM   #27
67ChevyRedneck
67ChevyRedneck's Avatar
Re: over heating
I'm stumped then
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-26-2009, 04:33 PM   #28
justtime520
Re: over heating
is there a real big difference in water pumps of that generation
Old 03-26-2009, 07:25 PM   #29
spinning wheels
spinning wheels's Avatar
Re: over heating
This is just an idea. Try running the engine without a thermostat.
That may or may not help the overheating.
Only other thing I would consider, is that you got a bad pump. Maybe the blades were installed wrong (backwards) during assembly. I would take it off and return it for either an exchange or refund.
There is a reason Checkers has a lifetime warranty. They know some of the pumps they sell are turkeys, but that may be 1 out of 100.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-26-2009, 07:56 PM   #30
westofb
I really hate wet sanding!
westofb's Avatar
Re: over heating
I have had new thermostats stick in closed position when install new. A few light taps on the house usually causes them to open up and work as intended. I did this with motor running and starting to get hot (thermo should have been opening up), gave it a couple of taps and it made a loud pop when it opened. This is real bad about happening if you used some type of adhesive to install the water neck gasket. I can't imagine it has a air pocket in it (unless your radiator is mounted lower than the water neck) or that the pump is turning the wrong way (I could be wrong, but am quite sure all reverse turning pumps are long style intended for serpentine belt use). If none of this helps, it is possible you have a head gasket leaking compression into the water jacket. Just some point to consider, good luck getting it going!
westofb is offline   Reply With Quote
Old 03-26-2009, 08:07 PM   #31
Kager67
what knocking sound?
Kager67's Avatar
Re: over heating
Well seeing as how we are grasping at straws here, this might work if it is an airpocket in there. Drain the coolant back out and remove the heater hose that goes to the intake and refill the radiator. Just be ready to put the hose back on or you'll have a nice mess! This gives the air a place to escape. Worth a shot anyway.
Kager
1968 C-10
1953 belair two-door post
1955 chevy 3600 big window
1950 studebaker starlite coupe
1968 Impala SS
Kager67 is offline   Reply With Quote
Old 03-27-2009, 10:02 AM   #32
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: over heating
http://67-72chevytrucks.com/vboard/s...d.php?t=335687
sneakysnake is offline   Reply With Quote
