#26 |
Re: I bombed emissions
Hey i thought Mass was bad with the same regs as california but arizona who knew. Actually Mass just took a step back and before every two years there was a emissions check on 83 and up if it wasn't OBD2 then they sniffed it while it was on the dyno. Now there only checking OBD2 vehicles so 95 and back and wahoo let the big motors roll.
67 C10 2wd Stepside (to be fleetside), Factory AC truck, Big Back Window, just got a 6.0/6l90e to jam in it now..... Needed: paint and lots of it. and i'm sure lots more misc. parts. Project 67 short step Build Thread 01 Sierra Crew 6.0 2015 Ford F150 Work gave me truck i really wouldn't buy a ford. |
#27 |
turn the air mixture screws in till it stumbles a bit, that wll lean out the idle, as for the co, make sure your timing is running off of a ported source.
#28 | |
Moderator
![]() Join Date: May 2007
#29 |
What carb are you running? Don't lean it out too much or your HC will go way up! Change oil, adjust timing to spec, replace air filter and you should be good to go.
#30 |
Emissions here are by county - the metro areas require it on 67 and newer vehicles. I have a 68 C10 and have to have emissions every year. Have a 65 Chevelle and it is exempt - no emissions.
#31 |
The inspection stations here are all run by the state - all the equipment and specs are the same and the guidelines are are tougher than Utah. That is the last place I had the truck I have registered and it passed emissions there also when it failed in AZ.
#32 |
No emissions required down here in Cochise County.
#33 |
I believe it is only Tucson and Phoenix - I have a 69 Camaro besides the 68 truck and have to have emissions each year also. I had it pass the way it is and had it fail also - that's why I just started buying the high flow mini cats - you can have everything dialed in and pass all the tests and be borderline on an idle test and not pass. The cats take care of everything so you don't have to turn up the idle lean it out retard the timing run methanol and make 3 trips to the emission station and wait in line a 45 minutes each time if it is busy. Someone else mentioned it earlier about the rich exhuast smell also - the cats take care of that also if that is something someone's concerned about.
#34 |
idle at 1500rpm
turn fuel screws in and back out 1 1/2 turns run it hard on the way there dont let it sit and idle as you wait tune up will help whether it be for emissions or just all around running better.... |
#35 | |
But way back in time. In CA, you had to smog your vehicles going back to '62. Or was it '64 model year? Anyways, it was a long time ago ![]() That was never fun. I remember having to pay $100 bucks under the table, just to get a smog check, so I could register a vehicle.
'72 GMC custom camper 350/350 |
#36 | |
Moderator
![]() I think I remember my dad telling me that '66 was the first year of smog. We/he was the original owner of a '65 Mustang and we never had to smog it. My neighbor had a '67 Camaro and had to smog it into the 90's. I remember my uncle having to slip old Barney a $50 to get his '72 F-100 smogged in the 80's ![]() ![]() |
#37 |
![]() Join Date: Mar 2009
On my way to emissions. with new edelbrock 650 thunder series. bring it on arizona air quality standards.
#38 |
![]() Join Date: Nov 2004
Best of luck, but what are these "smog" tests you speak of, we don't even have inspections here
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#39 |
In AZ if you have classic car insurance you can get an exemption. Just did it with my 83 swb and will do it with my 71. My wagon is 1965 and doesn't need it.
#40 | |
spirit rider66
![]() Join Date: Oct 2008
Location: pahrump, nevada, in the bowels of the Mojave desert
:Chevy: If you don't run your own life,, some one else will. ![]() ![]() ![]() |
#41 |
Move to Canada..everything older then 1987 bypasses the Government scam. What a joke. They oked to build them all then because it is destroying the world WE have to pay for it....crazy Gov is Cut Off
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#42 |
yip, gotta love the canadian emissions standards.
everything i drive doesn't need to be tested, but im pretty sure the standards or requirments get worse, or less, as you approach the 1987 model year (as in its easier to pass).. dont know how the emissions works in the states.. do you just have a go/no-go policy?
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
#43 |
Your only required to have cats on it if it originally came with cats. I believe its 66-74 or 75 you have to get the sniffer test but no visual and after 75 or so they start lifting the hood to make sure the smog equipment they came with is still on the vehicle ie.. charcoal canister, catalytic converter, smog pump. Its a pain. Its also only in the Maricopa county/ Phoenix area and Tucson. Most of the outlying areas are not required, unless you commute to Phoenix or Tucson for work.
#44 | |
Moderator
#45 |
Ok so i changed the carb and love it. leaned the hell out of it and put a bottle of rubbing alcohol in tank and filled her up with 87 grade. ran it around town for about 20 minutes and took her to emissions and passed with flying colors. So the first time i went i had to spin the tires on the wheels. I asked a guy there why i needed to do that and he told me that if it doesnt pass the standard idle test then they use the wheels thing to get the engine working hotter like a second chance. the standard is 5.00 i got a 2.29 and the first read was 7.something. Ya daddys rolling in his c10 again
#46 |
Glad it worked out, sucks to have to pay again for the 3rd time.
#47 |
Moderator
Right on
#48 |
What a change from when I was in AZ about 20 years ago when it was anything goes.You never knew what you`d see coming down the road.
I`ve never had to deal with smog,except for my wife`s newer stuff that always passed,except the`99 ZR2 that needed the converters replaced.I "cleaned" the converters out but was worried if it would pass the test.My drag racer/mechanic buddy said not to worry.We`d just put some magic juice(race fuel) in there and she`d pass with flying colors.
#49 |
Congrats on passing. Again, I'm so glad SC has NONE of that crap. I hated having inspections done every year back when I lived in NY.
#50 | |
![]() Join Date: Feb 2003
1971 K5 CST Blazer 1951 -3100 5 window short bed 4sp 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
