Old 04-01-2009, 10:46 PM   #26
Green Machine
Green Machine's Avatar
Re: My alternator wont charge! please help!!!
Original harness has a ground wire, plus the big red and the other two that ran to the regulator. Black wire was grounded to the rad support and the other end to the alt. Might want to add one if it is not there.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-02-2009, 03:35 PM   #27
soba_03
soba_03's Avatar
When I pulled out the original 307 my alternator was grounder to the manifold heat shield. After the new motor went in I didn't realize that I hadn't hooked it back up. killed my battery trying to get the new motor started. Once it did start and ran couldn't get battery to charge. Found the Rogue gound wire and stuck it right to the inner fender lip. it works perfectly. I believe that the alternator diagrams are on the site Electrical Forum and a "sticky" Under wire diagrams. Have a look. A ground is necessary.
soba_03 is offline   Reply With Quote
Old 04-02-2009, 08:58 PM   #28
djimenzj
The battery is grounded to the chassy, and its a new big fnn wire, I give up, I still havent check the PUSH START BUTTON, maybe its that.???
djimenzj is offline   Reply With Quote
Old 04-03-2009, 06:24 AM   #29
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
The battery ground doesn't go to the engine block first?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-10-2009, 04:10 PM   #30
djimenzj
Hey GrapDawg, thanks alot man!!! I added an xtra ground wire to the alternator and it works, turned it on and diconnected the positive and it stayed on!!! thanks a mill man!!! thanks everyone else you guys saved me a trip to the shop. woo hooooooooooooo
Old 04-11-2009, 01:40 AM   #31
Grapdawg
Driven a 72
Grapdawg's Avatar
No prob, your problem just sounded to similiar to mine so i figured.. Glad you got your wheels back in order, now go take it for a spin for me.
1996 GMC JIMMY
1972 CHEVY C10 LWB
My 72 c/10 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=318729
Grapdawg is offline   Reply With Quote
