Old 04-02-2009, 09:11 PM   #26
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: best way to increase top end speed in a 1967 K20
Reasons I don't speed
1) Bad front shocks, small bumps can get big. Never mount nitro shocks shaft down again....
2) Inaccurate Speedo, I don't know how fast I'm really going. I just know 100 is roughly 70 mph and that's all I normally do. Unless I turn on the GPS
3) No tach, if I choose to speed in third, I'd have no idea how fast she's spinning. Though, I can listen to it.
4) Gas money
5) A loud, bright orange truck, does tend to get attention enough at 65. A big orange truck with the engine running hard, gets even more. The police would love me.
texanidiot25 is offline   Reply With Quote
Old 04-02-2009, 09:35 PM   #27
69DISASTER
I have the same problem I have a 72 GMC with that Bulldog of a tranny (SM465) and 410 rear end and the truck screams at 70mph thinking of going with an NV4500. How big of a job is it?
69DISASTER is offline   Reply With Quote
Old 04-02-2009, 11:03 PM   #28
Critter
Future TOTM Winner
Critter's Avatar
Pretty big, huge in my opinion if you are putting it in a 4x4, even BIGGER if you intend to mate it to your original transfercase. Damn cool if you can afford it and pull it off.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 04-03-2009, 12:09 PM   #29
jamieg
im running a 400 on SM465 with 4.10's on 31" rubber.
I dont get anywhere fast, but on the bright side it gives people a better look at what a real truck looks like
I am changing up to a 700r4 and 35" rubber tho, which "should" drop me to about 1600ish rpm hiway speed. Which is just perfect for cruzing to the car shows
jamieg is offline   Reply With Quote
Old 04-03-2009, 04:13 PM   #30
1972CheyenneSuper
1972CheyenneSuper's Avatar
I'm surprised nobody mentioned these guys yet. http://www.gearvendors.com/index.html
1972CheyenneSuper is offline   Reply With Quote
Old 04-04-2009, 08:03 PM   #31
texanidiot25
Eat My Rust
I think an OD unit would drastically start moving things like the x-case, and its x-members around. Plus having to change drive shaft legths to compensate for it as well..
Old 04-05-2009, 01:36 AM   #32
72JimmyDiesel
a 67 k20 would have an eaton rear, 4.10 is the highest gear set offered in the eaton and most 67K 20 trucks would of had 456's especially the 6 cylinders.
72JimmyDiesel is offline   Reply With Quote
Old 04-05-2009, 01:37 AM   #33
spinning wheels
spinning wheels's Avatar
I have looked at them. It is not cheap, easily over 2500 bucks. From what I was told, it is a modern version of the OD that the British Morgans' used to use. Not sure if it was the same electronic OD that Volvos used to use.
The commercial unit would be the stronger of the two units that they sell. That was what I found out, when I researched them and spoke to their reps about 4 years ago.
On a bright side, if you can find a newer wrecked or burned up Motorhome, it might have a gearvendors overdrive unit. What cool about these ODs, is that a 3 speed becomes a 6 speed.
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 04-05-2009, 11:07 AM   #34
sierra4x4
sierra4x4's Avatar
My DD 85 K20 has a 250 with a SM465/208 combo with 4.10's and 235/85r16 tires which are 31.5 inches tall I run at 3100rpm at 70 mph.
sierra4x4 is offline   Reply With Quote
Old 04-13-2009, 02:34 PM   #35
jamieg
http://www.snoman.com/HTML/axlecalc_5a.html
give that link a try to help get ya a little closer to what your looking for
Old 04-13-2009, 07:23 PM   #36
onlyifihadachevy
i like that you want to go pass the 100 in a old 4x4 thats my goal too. But different gears or a overdrive should get you a little faster i belive. how do out what your top speed should be.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 04-13-2009, 09:05 PM   #37
JAKES 68GMC
Aluminum slot wheels rule...
I had my needle buried a time or two with 4.56 gears, and a time or two with 4.10 gears. Surprising, the truck was really stable at those speeds. But I won't do it again anytime soon.
JAKES 68GMC is offline   Reply With Quote
Old 04-13-2009, 10:09 PM   #38
onlyifihadachevy
nice thats my plans for my 350/th350 with 4.10s if it doesnt blow up.
My 72 thread
