#26 |
Re: FuelCellGuy- Forum Special on Fuel Cell- Till April 30
Hello, i am very interested in one of your fuel cells. I have a 1969 gmc, with a 1995 chevy stepside bed. It has the fuel door on the front of the fender. I'm not sure if i would have to move the filler to the rear of the fender or what, but i would like it to fill on the side. These come with all of the brackets and everything right . How much to ship to okc with a business address?
Thank you! Chris |
#27 |
FUEL CELL GURU
The filler location would have to be moved the rear. Shipping is generally $50. These come with brackets/bolts, no brass is included. Are you looking for carb or f.i. application?
#28 |
![]() Join Date: Oct 2008
Can I get a picture that shows the final welds up close (cleaned).
I just tend to pay alot attention to detail. Thanks
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
#29 |
Do you think You could sell a weld it your self kit? If so I would definitely take one depending on $$$$$..... thanks let me know
Also I see a lot of tanks installed on trucks that have a roll pan rear bumper and they all hang below the bumper... is yours the same??? if not do you have any pics of it installed from the back???? Thanks |
#30 |
Its carb right now. Thanks!
#31 |
FUEL CELL GURU
C10Sim, as soon as I build another I wil get some close-ups of the welds (next week).
bmfpeterson, Let me see what I can do. Mine does not hang below the roll pan/bumper but MAYBE and 1". I'll dig some pics up. 6T9GMC, ready to order? |
#32 |
Garage wrench
Do you do anything for the 73-87 GM trucks?
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
#33 |
FUEL CELL GURU
SBTork, all I need are dimensions. I can build pretty much any tank.
#34 |
Garage wrench
Ok, if I were to have you build me a custom tank would there be a discount on that too?
#35 |
FUEL CELL GURU
ALL my tanks are custom and reasonably priced.
#36 |
Thanks,
I'll check out the pics that you post and go from there. I would be really interested in a weld it yourself setup!!!!!!!!!!!!!! I just got a new tig setup and have been hangin out in my garage drinkn beer and weldn any scrap I have ( or should I say had) and I'm all out of aluminum. Ha ha Thanks |
#37 |
Licensed to Thrill!
Just now saw this (not on forum much lately).
I am sure you have made one before for my app, just need to find out. '71 SWB, with ECE Hidden Hitch... This isn't a problem on most of the tanks, just wanted to check. I have a modified stake pocket fill. (I do have a neck I can use). Do these tanks clear the above? Tired of seeing the hole inside my bed with the tank still behind the seat. Thanks. DLB Last edited by Orange; 04-22-2009 at 09:09 PM. |
#38 |
FUEL CELL GURU
Orange,
From the feedback I have gotten forn this site, it will fit with the ECE hidden hitch, I have personally have not done it myself. The filler shouldn't be a problem either. Mark |
#39 |
It's the 30th!!!! not to bug you but I am still very interested in a weld up your own kit, and a few pics of a tank installed with a roll pan bumper setup.....
Thanks |
#40 |
FUEL CELL GURU
Special has been extended until May 31st!
#41 |
FUEL CELL GURU
bmfpeterson,
Here are the pics. Keep in mind, this is when I was suppying the tanks with straps. Later, Mark |
#42 |
Re: FuelCellGuy- Forum Special on Fuel Cell- Till May 31*
will these tanks clear the crossmember on the bed floor? my blazer tank would not. thanks
#43 |
FUEL CELL GURU
Yes they will.
#44 |
Mark,
Do you know where I can find any pics on a thread that shows how the filler neck goes into the rear tailight? |
#45 |
#46 | |
Is it done yet?
FuelCellGuy, I have a 72 SWB and I am running the filler in the drivers side tailight. Do you already make a tank for this setup and what else would I need to get to finish the install minus your kit? Also, I was concerned about the tank hanging to low in the rear below the bumper but will be putting a 4" drop in the back. If you made a 25 Gallon tank would that be too big for my truck and would it hang too low below the bumper? If you cant do 25 Gal what is the largest vol. tank you could make for this truck? I dont mind if its below the bumper a few inches. I could just powder coat the tank black. My set up is Carb. Shipping would be to 35904 Thanks, Brian
1972 Chevy SWB New 383 Stroker/350 Turbo Some day i'll paint it John 3:16 MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=398108 |
#47 | |
Sorry, here it is.-> http://67-72chevytrucks.com/vboard/s...e+swap&page=15 |
#48 |
FUEL CELL GURU
Brian,
The standard fill tube is in position for the marker light fill. The standard 18 gallon tank hangs below the frame rail 4 1/2". If the tank were an inch deeper that would yield about 21 gallons. Take a look at your truck and see which direction you would like to go. Thanks, Mark |
#49 | |
Is it done yet?
I cant look at my frame at the moment. Im back in Iraq and wont be home until the first week of August. Looking at the pics above on your truck, is that the standard 18 Gal tank mounted under the bed? If it is, I dont think an extra inch would look that bad if I drop the rear of the truck 4" and use the original step bumper. Can the tank with the marker light fill tube be used for my rear tail light fill set up? Also, if the tank were a inch deeper and I had the 4" below the factory standard rear height, how would the ground clearance be? If you know. I would like to possably order one of these and have it ready when I got home. Thanks, Brian.
#50 |
"Trucks with Class"
![]() Join Date: Jul 2000
Hi Mark,
I sent you a PM on Blazer tanks. Thanks, Frank |
