Old 04-19-2009, 04:17 AM   #26
originalJD
James
originalJD's Avatar
Re: Your thoughts on this motor I got for my truck
Originally Posted by Captainfab View Post
With those flat tops and the ~64cc chambers of those heads you should be around 9.5 to 9.7-1 depending on deck height and gasket thickness. Have you determined if they are cast, hypers, or forged? Is the block a 2 bolt or 4 bolt. Sorry for all the questions, just curious
Hey I don't mind the questions. They actually get me thinking. Like the pistons. I never thought to figure out what they are. I do know that the block is a 4 bolt main. Also I'm fairly certain the deck height is standard. The suffix code is still there and doesn't appear to have been re stamped. Heads seem to be standard too. As for gaskets, I'm thinking of a set of Mr Gasket with copper head gaskets. Thin.
After a closer look today while doing some clean up. I found that something was banging around in the #5 cylinder. Looked like maybe a screw from the indentions on the head. Most likely the main reason for the last rebuild. All signs indicate it was prior to the rebuild. No damage to valves, piston or cylinder wall.
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end.
http://viewmorepics.myspace.com/inde...lbumId=1709080
http://s258.photobucket.com/albums/h...e_top_view_all
originalJD is offline   Reply With Quote
Old 04-19-2009, 08:40 PM   #27
originalJD
James
originalJD's Avatar
Well here's a few shots of what I got done today. Everything checks out great. I replace the timing chain and cleaned everything up real good. The dress up kit is only temp. just for look while it sits for now.
Old 04-19-2009, 11:45 PM   #28
Captainfab
60-66 Nut
That's lookin good
The intake cleaned up nicely too. Are you going to use the stock thermostat housing? I actually prefer the stock ones, blasted up nice like the intake. Those chrome Chinese POS ones just don't last.
Old 04-20-2009, 12:45 AM   #29
originalJD
James
originalJD's Avatar
The intake is in primer. But yes, it did clean up nicely. I will finish it with a High Heat aluminum paint. It's only a temp also. The intake in pic below is what I'm going with.
Thanks for commenting on it.
Old 04-30-2009, 07:27 PM   #30
TwiggyTheDrummer
Keep It Simple Stupid.. Nope..
TwiggyTheDrummer's Avatar
Looking good man. I'm ready to see it go in.
1963 GMC SWB Fleetside in Sunburst Orange Metallic
305E V6 w/ Plaid VC, Powerglide, BOSS 313 20" Chrome Wheels, Kumho Ecsta STX 275/45/R20's, Alpine/Clarion System, Dynomax Exhaust
Old custom classic trucks have soul. Their dashboards aren't plastic, and they've survived both the best and worst of what the 20th century had to offer. For the owners of these trucks, it's often the same story. Through both good and bad times they persevered, until one day they could turn the key and roll up in a customized truck everyone with good taste would admire.Custom Classic Trucks
TwiggyTheDrummer is offline   Reply With Quote
Old 05-03-2009, 01:47 AM   #31
originalJD
James
originalJD's Avatar
It gonna go in next week end if the weather permits. I finally got everything I need except the Accel power power coil I want. I'm currenly preping the headers to go on. I'm getting kind of impatient with it so I'm going to drop it in the camaro I pulled it out of long enough to fire it up and get it tuned. Once thats done I'm yankin it back out to get it ready to drop into the truck. I still have alot I haven't put on it yet but here's some pics.
Just for fun
Old 05-06-2009, 01:01 AM   #32
originalJD
James
originalJD's Avatar
Old 05-06-2009, 01:04 AM   #33
70 Suburban
Rods
hmmm chrome pan has always been bad mojo for me but the rest looks great
70 Suburban is offline   Reply With Quote
Old 05-06-2009, 01:08 AM   #34
originalJD
James
originalJD's Avatar
I've never used a chrome pan before. I was going to restore the old one but I got this one just because. Thanks for the comment.
Old 05-06-2009, 01:15 AM   #35
70 Suburban
Rods
they just tend to leak and push seals out....
Old 05-06-2009, 01:22 AM   #36
originalJD
James
originalJD's Avatar
I kinda figured I might have problems with drips with some stories I've heard. So I was very generous with the high temp cylicone sealer.Hopefully it does the trick. Now that I think of it, I probably should have scuffed the surface at the ends. I'm going to restore the old pan just in case.
Old 05-06-2009, 11:51 PM   #37
Captainfab
60-66 Nut
Ummm I've never seen a motor mount like that on the block. Usually see them on the crossmember in the car or truck.
Old 05-07-2009, 12:01 PM   #38
originalJD
James
originalJD's Avatar
The motor mounts you see are to the 80 camaro I pulled the motor out of. I still have the original V8 mounts for my 66. I'm going to leave the trans off and drop the motor down into the camaro long enough to fire up and work out any bugs. Hopfully I can do it this weekend. Once thats done I'm putting it back on the stand while I save to get the exhaust pipe and mufflers for the truck. My truck is drivable as is with the 292 in it and I dont want to drop the 327 in it if I can,t drive it. I hate being broke. I've been laid off since feb. If anyone wants to donate a 3" exhaust system I'm all for it.
Old 05-07-2009, 03:37 PM   #39
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
Originally Posted by chucks1967 View Post
I say build a motor to match the heads!!! a 302 would be schweet! and they run great!
if he was to build a 302 he would have to get some custom bearing spacers or a custom ground crank
302s were high winding and made a lot of power for their cubic inch but you know what they say
theres no replacement for displacement
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 05-07-2009, 03:44 PM   #40
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
why dont you just start it up on the stand make a stand for the radiator that sits in front of it
it should save you a lot of time than putting it in the camaro pulling it back out and putting it in your truck
Gage
Old 05-07-2009, 04:22 PM   #41
originalJD
James
originalJD's Avatar
I have thought about starting it on the stand. But the stand I'm useing is cheap and needs alot of reinforcment to do so. That, and I would have to build a radiator stand and a gauge panal and buy more gauges. I do have plans to build a universal engine test stand. Just not right now (no money). Besides, it's not all that difficult to drop it down in the car and hook it up just to start it. The only thing that does make the task more difficult for me is the fact my work area is outside in dirt and gravel. Man, What I wouldn't give for just a simple small shop.
Old 05-07-2009, 06:35 PM   #42
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
heres some pics of the one i made
if you was closer you could use it it has a spot for a battery radiator and ignition switch it needs a fuel cell
Gage
Old 05-07-2009, 06:43 PM   #43
originalJD
James
originalJD's Avatar
Thats cool. I have a welder and I'm good with metal work. I just gotta get metal. LOL! I didn't notice you were from TX till now. My home town is in Abilene TX.
Old 05-07-2009, 06:48 PM   #44
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
man 60 miles
do you ever come down
Gage
Old 05-07-2009, 06:55 PM   #45
originalJD
James
originalJD's Avatar
No. I moved here 9yrs ago and never went back. Cant afford the trip taking the whole family. I will go back and visit somtime soon. My parents and my brothers and sister live there. I sure miss TX.
Old 05-07-2009, 10:38 PM   #46
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
is it hard finding parts for trucks up there
is it cold in washington
it was about 90 today here
Gage
