#26 |
>130dB Moderator
Re: Best $15 I ever spent.... Corvette Servo!
I'll be careful, but I'm not too worried. I have the original (not reprint) shop manuals for the truck and I'm usually really thorough when it comes to this sort of thing. It may be a 20 minute job on paper, but with cleaning, pictures,and the way I normally snowball a job, this will take me forever...
Living Life @ 130dB LED Tail Light Conversion; How-to Friend. Father. Brother. RIP El Jay ------------------------------------------------------------------------------------------------------------------------- CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum. |
#27 |
Hey guys, I figured I would also change the fluid and filter since I don't know when it was last done (bought truck used). There were only 2 filters available at the parts store, one for the 3 speed auto and one for the 700r4. I obviously bought the 700r4 filter kit.
The filter looked the same as the one that came out but it is making contact with the pan? I was able to bolt it all up but it kind of made me a bit nervous with it hitting the pan like that. I heard that the pan is actually suppose to make some contact with the filter to keep it in place?
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch |
#28 |
Right turn Clyde
So do you reuse your "pin" the part the goes in the center?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
#29 |
Hey all, I have zero experience with transmissions other than a routine filter fluid change. Is this a safe mod to do without any other trans mods like a shift kit?
Does it put any further strain on any other components? I have always viewed my 700r4's as disposable due to the fact that they are always the first thing to go in my trucks. Any input would be great |
#30 |
Yes it is safe if installed correctly. No it will not strain other components.
1972 GMC C10 |
#31 |
Location: Where I come from, it's cornbread and chicken...
can I use this on a 700r4 behind a 6.2l diesel...thanks
Chuck. |
#32 |
1972 GMC C10 Last edited by Manbearpig; 04-19-2009 at 03:45 PM. |
