#26 | |
Re: A Hard Lesson Learned.....
All you have to do is pull the dipstick to see if there is any water in the oil. If there is, it will look like milk on the dipstick. You might not be in bad shape after all. If you do a head swap make sure you stick to a composite head gasket that's .028 or thicker. The deck of the block may be slightly warped and since we're shooting for salvage yard heads, you probably don't want to pay for a valve job/head mill. If you get the heads from the slavage yard try to get the head bolts with them. Yours may be compromised or weak. |
#27 |
P.S. Sorry I don't have any comments about your personal family business. I'll try to make up for that by offering you extra help with the motor problem....................
#28 |
![]() Join Date: Dec 2008
The bottom end is probably alright, the top end is probably toast...I would find a set of heads first, Old Small blocks are pretty tough.
#29 | |
spirit rider66
![]() Join Date: Oct 2008
Location: pahrump, nevada, in the bowels of the Mojave desert
:Chevy: If you don't run your own life,, some one else will. ![]() ![]() ![]() |
#30 |
my friends dad has 23 small block chevy engines... he wants to get rid of some.. they are blocks and some parts for it.. u can get one from him really cheap..
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
#31 | |
Any of them 4-bolts? Last edited by highperf4x4; 04-20-2009 at 03:05 PM. |
#32 |
ya he has some four bolt mains.. and he has intakes laying around.. pm me for more i dont wanna steal this thread
#33 |
Actually I was asking questions for Greg. He really just needs the "heads" but in the event that the bottom end is out the door too, he'll be needing a 4 bolt block.
I might be interested in one of them myself though so I will pm you about that later. |
#34 |
And Greg, can you drop us the info on the motor? Year, size, generation, aspiration, etc? You'll need to know that to pick the right heads.
#35 |
Engine is an '88 350, not sure of the generation/asperation, etc.
It's gonna have to be fully replaced. Lots of water getting into the oil. It's visible on the dipstick, on the cap of the valve covers, and drained out ahead of the oil this afternoon. So, it looks as if the whole thing will have to be changed out. Greg |
#36 |
Yeah that kinda sounds like a split cylinder but you still don't know for sure. A head gasket could do that as well. You might try just pulling the heads off and spinning the motor so you can check each cylinder wall before you pull the motor out.
The block in my 4x4 has 2 cylinders that had to have steel sleaves put in after running it in a drag boat one weekend. Last edited by highperf4x4; 04-21-2009 at 12:58 AM. |
#37 |
I would recommend checking out craigslist in your area, i picked up a brand new set of 76 cc 350 heads for 375, and 350 block that was bored, fluxed, bearings and freeze plugs installed, with a balanced crank, rods and flattop pistons, with a brand new crane cam, and alot of other misc. parts for 425. So all in ill i have roughly 900 in brand new engine.
On a side note i did the exact same thing to my first c10 when i was 17. It ended toasting the entire engine and breaking a piston off a rod when the piston melted to the cylinder wall. ![]() My truck was out of commission for about a year while i worked up enough cash to buy a crate motor. In any case good luck. |
#38 |
Engine n00b
where in tx again?
#39 |
AMERICAN IRON ADDICT
These trucks came from the factory with steel shim intake gaskets. They are very prone to rotting out and leaking coolant internally. I would pull the intake first and see what the gasket looks like. if it's not rotted or displaced, i would continue with pulling the engine and replacing it. When I worked for gm in the 90's we were doing these all the time under warranty. You would be surprised what abuse these things can take. If the gasket is bad replace it and change the fluids and see if your lucky. Alot less money and time if it works out in your favor. Just A thought good luck!!
#40 |
![]() Join Date: Feb 2003
i not only bought engines for all (3) of my kids but i also purchased and fully restored each of them a classic car.. 2-in school and one married and working 4-10's.. all for love!
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
#41 | |
I built it
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
#42 | |
![]() ![]() as for engines id send you some but im way up north. id take highperf4x4's advise and tear it apart while still in the vehical and see if its salvagable
eh ![]() 1970 Chevy C20 daily driver ![]() 1975 GMC Jimmy 4x4 project ![]() 1966 GMC C10 Dad's project ![]() Last edited by Camper Power; 04-21-2009 at 08:37 PM. |
