Old 05-10-2009, 12:28 AM   #26
88 Dippy
88 Dippy's Avatar
Re: whats the difference?
the bolt pattern is the same on all the of them if you get one that was in a vehicle with a chevy V8.
i have no idea what would be the best for mountain driving because i live in a preaty flat state sorry
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels
2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost
88 Dippy is offline   Reply With Quote
Old 05-10-2009, 03:05 AM   #27
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
ok, If I was in your situation. I would call around and find out how much it would cost to re-build Your TH350 with HD parts. then find out how much it would cost to do the same with a TH400. as I see it, TH350s are Great with a stock SBC up to a 350 motor. with light to occasional medium hauling in stock format. if I was to get a motor that was not stock or was going to do towing or lots of hauling up the mountains, I would go with a TH400. But I would start out with the numbers first and see what my pocket book can handle and time frame *if you need your truck running next week, kind of thing*. and go from there. I think either trans would be fine for you. I've heard that the 700's cost A lot more to rebuild right. and the amount of money you would save on gas. it would take a while to recoup the difference of a 350/400 rebuild and a 700. JM2C
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 05-16-2009, 04:31 PM   #28
dga93
newbie
dga93's Avatar
So I found a th350 for $70. I hope it works. Find out tonight.
I have been without my truck for over 2 months.
Anything I should do b4 I put it in? Or add while I'm putting it in?
dga93 is offline   Reply With Quote
Old 05-17-2009, 01:02 AM   #29
79gmcc15
79gmcc15's Avatar
well if you can't have it checked before you put it in. at least have all the fluids changed and filter. its pretty easy to do. I am sure someone can add to that.
RIP ELJAY
Old 05-17-2009, 06:53 AM   #30
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Be sure and measure the lengths of your old TH350 and the new one to make sure they are the same length. There are 3 different length 350 trans.
