Old 04-26-2009, 10:00 AM   #26
5150
C10 Club Tennessee
5150's Avatar
Re: One side higher then the other side
yes, it was just from the frame to the ground. I'll get a measurement from the frame to the trailing arm.
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 04-26-2009, 10:17 AM   #27
LONGHAIR
I would have to agree with see ten in the statement about weight distribution. With a single line tee'd together, the truck can tilt toward the heavier side....but you can't ignore things that could cause any kind of travel limiting either.
I realize that it is a bit of a PITA, but can you swap bags from one side to the other?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 04-26-2009, 10:22 AM   #28
5150
C10 Club Tennessee
5150's Avatar
I don't believe that there is anything on one side of the frame that's not on the other side other then the air tank, and hell, it's on the higher side.
Bryan
www.gmtruckshow.com
Old 04-26-2009, 10:34 AM   #29
5150
C10 Club Tennessee
5150's Avatar
okay, measured the frame to the trailing arms. The passenger side trailing arm is farther away from the frame by almost an inch compared to the driver's side.
Bryan
www.gmtruckshow.com
Old 04-26-2009, 11:01 AM   #30
see ten
WTB this ad
see ten's Avatar
Is that at full lift and at full dump? I can explain it at full lift just by the fact that you're air line is Teed and one is obviously getting more air then the other. I don't have a good explenation for it at full dump. You could swap the bags from one side to the other and see what happens.
You could always just keep a cooler full of ice and your beverage of preference in the high back corner to try and level things out??
see ten is offline   Reply With Quote
Old 04-26-2009, 11:01 AM   #31
5150
C10 Club Tennessee
5150's Avatar
also, I can actually push down on the high side and it gives so it's not like it won't give at all.
Bryan
www.gmtruckshow.com
Old 04-26-2009, 11:20 AM   #32
5150
C10 Club Tennessee
5150's Avatar
at full dump, the passenger side of the frame is just over 2 1/2 inches from the trailing arm.
The driver's side is 3 inches from the same spot on opposite side.
Bryan
www.gmtruckshow.com
Old 04-26-2009, 11:21 AM   #33
FnLow69
FnLow69's Avatar
If you hold the dump switch will the passager side continue to air out and be level? you might have unequal length air lines....
FnLow69 is offline   Reply With Quote
Old 04-26-2009, 11:23 AM   #34
5150
C10 Club Tennessee
5150's Avatar
almost, it's not quite even, but ALOT better. The driver's side bottoms out first then the passenger side continues down a little bit farther.
Bryan
www.gmtruckshow.com
Old 04-26-2009, 12:42 PM   #35
hotrodhomi
hotrodhomi's Avatar
Are you sitting in it? 3 bills can make a big difference.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 04-26-2009, 04:39 PM   #36
LONGHAIR
Just because a man has $3 in his pocket?
I assumed that he was taking the pictures?
Old 04-26-2009, 08:14 PM   #37
lolife99
67-72 parts collector,…
lolife99's Avatar
Separate your rear bags.
Get rid of the tee.
One fill, one dump for each one.
Keith
Convert to disc brakes.
Old 04-26-2009, 10:23 PM   #38
gringoloco
A guy with a truck
gringoloco's Avatar
Get rid of the tee.
You can also add a ball valve inline. That way, you have one schrader and the bags are still isolated.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-27-2009, 11:16 AM   #39
Tony@AirRideTech
Junior Member
exactly... If I had to guess you probably dont have a sway bar on it, and you are running the lines tee'd in the rear. You need to seperate those lines and add a sway bar if you dont have one. It is not uncommon for one side to take more pressure than the other to level the truck out.
Tony@AirRideTech is offline   Reply With Quote
Old 04-27-2009, 11:22 AM   #40
fixit-p
fixit-p's Avatar
I hate to state the obvious here...but have you tried putting the $3 in the other pocket and see if that helps
On a more serious note how about pulling the bag on the side thats higher when aired out if it comes down its probably the bag if not it could be a twist in the frame
fixit-p is offline   Reply With Quote
Old 04-27-2009, 04:27 PM   #41
5150
C10 Club Tennessee
5150's Avatar
I have a sway bar on the front, but not on the back.
I think I figured out the problem. I only have two switches, front and rear. I have 4 valves up front two for each valve. I have 2 valves in the rear for both bags. The front line is tee'd off and goes to both sides before entering the valves.
After some help from csbatey we figured out that the front passenger side is also about an 1 inch higher. That is also what is causing the back to be unlevel.
Bottom line is that I'm getting two more switches and two more valves and each bag will have it's own switch and each bag will have two valves apiece.
Bryan
www.gmtruckshow.com
Old 04-27-2009, 06:00 PM   #42
70k52wd
Blaze-Air
70k52wd's Avatar
Plug & play...You betcha.
70k52wd is offline   Reply With Quote
Old 04-27-2009, 08:44 PM   #43
see ten
WTB this ad
see ten's Avatar
You can barely see Christy's controller lying on the seat. I think you'll be immensly pleased with something like this. We generally hit the center switch for the initial lift and then fine tune the corners with their individual rockers switchs. A couple of dual needle gauges would help as well.
We've also noticed that lifting a front corner can cause a rear corner to lift with it.
Any idea of what caused that bag to fail bro???
Old 04-27-2009, 11:36 PM   #44
5150
C10 Club Tennessee
5150's Avatar
yea, apparently it was the sway bar. It sticks out about an inch from the bushing/bracket and the bag apparently been resting on it.
Can I just cut a little off of the sway bar?
Bryan
www.gmtruckshow.com
Old 04-28-2009, 09:58 PM   #45
bagged74
its just $$$$$
bagged74's Avatar
yeah you can trim the end with a cut-off wheel or something. just done use a torch.
bagged74 is offline   Reply With Quote
Old 04-28-2009, 11:21 PM   #46
5150
C10 Club Tennessee
5150's Avatar
I installed the sway bar with the front end way up off the ground. I didn't install it at ride height. I'll see what it looks like at ride height before I cut anything off.
Bryan
www.gmtruckshow.com
Old 04-29-2009, 04:44 PM   #47
see ten
WTB this ad
see ten's Avatar
Just don't cut off so much that the bar slides out of the bushings when you're at full lift.
Old 04-29-2009, 10:05 PM   #48
lolife99
lolife99's Avatar
Have you thought about switching to an Addco sway bar with end links?
I think you can get them thru Porterbuilt.
Keith
