Old 05-29-2009, 10:58 PM   #26
bubba327
HOW long until spring??
bubba327's Avatar
Re: Cheap cheap bed floors??
Grumpy-I Saw a 66 long bed with TREX decking (the plastic boards) and chrome strips that looked really nice. I am planning on using that for my 64 shortbox. Use your router just like on wood.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 11-03-2018, 10:49 PM   #27
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
So, an 8' sheet of plywood is long enough?
66 C20 Service Truck:
Old 11-03-2018, 11:43 PM   #28
AcampoDave
AcampoDave's Avatar
Originally Posted by TwoFiftyShifter View Post
Use a sheet of plywood and mount your strips right over it, shuold look and work fine.
That's what I did. 2 sheets exterior grade split in the middle. Longbed needs 9 foot sheets
AcampoDave is offline   Reply With Quote
Old 11-04-2018, 12:13 AM   #29
Captainfab
60-66 Nut
Are you asking about a shortbed or a longbed? IIRC the wood in a longbed fleetside measures 97.5"
Old 11-04-2018, 02:15 AM   #30
LostMy65
LostMy65's Avatar
Sorry,
I was asking for a longbed.
Old 11-04-2018, 12:15 PM   #31
jayoldschool
Moderator
Not long enough for a longbed. I used 10' lengths cut down.
jayoldschool is offline   Reply With Quote
Old 11-05-2018, 01:24 PM   #32
whatleyr
I used composite boards for mine. Changed them this past summer. You will actually use the Facia boards instead of the deck boards. I got mine at Lowes. It is the gray color. I painted my metal strips black. Looks like an old truck bed but it won't rot. The only thing I would do differently is to add a cross member at the back end just past the fender wells. It is sturdy and looks great. Adding a cross member would make it even sturdier. I'll post pics if you need them. Take care.
whatleyr is offline   Reply With Quote
Old 11-05-2018, 01:48 PM   #33
Android04
Android04's Avatar
I did the exact same!
Android04 is offline   Reply With Quote
Old 11-05-2018, 09:53 PM   #34
Blue666(2)
Treated 3/4" plywood & stainless steel strips.
As Mr. Spock would say: "Crude but effective".
Blue666(2) is offline   Reply With Quote
Old 11-06-2018, 10:09 AM   #35
jchav62
1962 C-10
jchav62's Avatar
My buddy hooked me up with some aluminum sheets...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 11-06-2018, 11:42 AM   #36
verdell
verdell's Avatar
Treated, torched, finished plywood from Lowes with painted strips. I think the finished product looked a little better with the hardware installed. I snapped this pic during the process though.
verdell is offline   Reply With Quote
Old 11-07-2018, 02:18 PM   #37
SCOTI
SCOTI's Avatar
I'm undecided on whet I'll use on my new/modded bed floor.
Any more info you can provide? Are the Facia boards 3/4" thick or a different dimension?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-07-2018, 04:33 PM   #38
whatleyr
Yes. they are 1x8's. Same dimensions as traditional lumber. Looked up the groove pattern and cut everything like a traditional board from the factory. Some say that the boards aren't rigid. Well.. Besides the back of your truck where you don't have a cross member, everything else works great. I just used whatever was at the big box store. I haven't restored my truck yet. When I do I may order boards in a particular color that would look nicer. I'll try to get some pics tonight.
Old 11-07-2018, 07:32 PM   #39
SCOTI
SCOTI's Avatar
Thanks. Additional pics never hurt
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-07-2018, 10:46 PM   #40
jayoldschool
Moderator
Google my TREX posts, you'll see exactly how I did it.
