#26 |
Re: Calling all LS Motor Transplants!
biggest issue with the LT1 is the opti. plus what is the cost of them, we get the 5.3/6.0 complete for cheaper than the LT1s....
#27 |
I did a 2001 5.3 4l60e swap absolutly loved it but it had a bit of piston slap when cold.(GM tightend the toerances in '03 to remidy this) so I used it as an excuse to swap in a 6.0 With a z06 cam. I never had to open the hood with either motors other than oil changes. Seems like I get about 15 a gallon.(had a 2001 2.2 four cyl s-10 that got 16mpg lol). The truck has much more power than it has suspention or brakes so it can get tense really quick. Another 50hp and a steeper gear and it will be perfect.
All in all it is now a bolt in deal that fits amazingly well and I think it is as cheap as freshning up your original drive line and the end product is ten fold. |
#28 |
IMO, the LT1 wasn't around very long... If I were to do it, I'd go with LSx
#29 |
and from a tuning standpoint, the LS computers and the software used is ALOT better and 'easier' to use.
#30 |
so im guessing no matter what on these ls swaps you cant use the factory tank.
#31 |
![]() Join Date: Nov 2003
#32 | |
Get an external fuel pump (E2000 is what I will be using). And then depending on the fuel rails you have you will either have the FPR on the rail OR you will need to use the vette regulator/filter. And for the return line I will just drill/tap/fitting a return hose in the filler neck. I am pretty sure that will work. Stock Fuel level gauge will work just fine too. |
#33 |
![]() Join Date: Apr 2005
Heres' 2 more.......
. . . . . . . Look in signature, ![]()
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
