#26 |
Registerd User
Re: Protrash Re-hash
What a great thing to come home to. Looks great vato.
#27 |
Resistance is Futile
Muchos Gracias....
OK.....started looking it over to really see where Im at. Looking pretty good as far as I can see. Made a list and started knocking things off....one thing that I didnt do a long time ago is now done. Filled the notches for the tailgate hardware. Next are those spotweld holes across the back; and sanding and sanding and sanding.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#28 |
#29 |
I know everybody likes to show off their welding skills; I like to show off my grinding skills
#30 |
can you tell me about your door handles i see they are missing what is the setup for that, i understand you can have somesort of electrical type of opening but how did you do it. looks very nice
#31 |
Basically you delete the handle, and use a solenoid to pull open the mechanism. The solenoid is activated by remote and then a spring in the lower corner of the door pushes the door open when the mechanism retracts. I also added switches to the set-up so I dont need the remote. If you look at the interior pic on the passenger side, next to the glove box is a small chrome button. This activates the solenoid to get out of the truck. Many places sell kits to do this and I will be upgrading mine in the future....stronger solenoids. Its a pain in the a$$ when you have your battery out or disconnected.
#32 |
Hollister, CA.
![]() Join Date: Sep 2006
Solenoids ? Did someone say Solenoids ?? Is the juice going in ?? Huh, huh..is it, is it ?!?!?!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
#33 |
![]() Last edited by jr's62; 05-12-2009 at 09:29 PM. |
#34 |
you know something that we don't???
#35 |
One day...
![]() Join Date: Apr 2008
ChiefRocka.... did you bump your head??
#36 |
One day...
Looking good Jeff!
#37 | |
Registerd User
Good to see progress Jeff. ![]() |
#38 |
so where are the pics?
#39 |
I'm still sanding and waiting for more progress......so we can go back in time and see what the truck looked like circa 2003.......
#40 |
wowsers!!
what is that piece of angle on the bed side above your gate cables?
#41 |
I originally built a metal tonneau cover that was simply too heavy and unworkable. Those were the supports. My buddy made a welding table out of it (kyle4381). Found a pic...I finally got pics off the thumbdrive from the X.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device Last edited by protrash64; 05-29-2009 at 12:26 AM. |
#42 |
oh...
![]() ![]() Last edited by joe231; 05-29-2009 at 12:29 AM. |
#43 | |
![]() Join Date: Oct 2006
![]() ![]() Nice work protrash
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
#44 |
Ok....heres an update. (Yes Joe, there are pics.
![]() My bed was a wrecked '66 trailer. I got rid of the wrecked parts and added a '62 bedside on the drivers side. I did not start out with premium parts. Its interesting to see the differences in the two sides. For instance, in '62 they bolted the chain hardware on and by'66 they spot welded it. It looks like they improved the stamping and tried to cut out waste metal as the folds have less excess by '66. Could just be variance in production for all I know. Anyway, heres the pics of progress......from the sides ripped down into the original bodywork and built up again to be straighter. I purchased a 24'' Durablock and use adhesive backed paper. This block improved my skills as it covers such a wide area it does not allow me to dig in and make a 'ditch'. I have then coated stuff with SEM self etch where I hit some metal and SEM high build in other areas. All of this will be coated with Extreme 2K primer eventually. Ok, enjoy.....
#45 |
...........passenger side........
#46 |
Sweet truck! Nice work too.
![]() 1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
#47 |
Registerd User
Looks good Jeff. Are you inside door handles shaved to?
#48 |
nice work!!
thanks for the pics ![]()
#49 |
Thanx guys.......yeah Jason, they are gone. I have push buttons installed on the dash corners to pop the door from the inside. I need to re-do the system to work better, but thats in the future. Im concentrating on the bed right now so I can call it 're-hashed'.
I figure the doors will be a section of the project as I have new weather stripping and Electric-Life power windows to install. I also found some damage that I will need to fix on the drivers door. This wasnt really exciting or anything, but damn its a lot of work!! ![]()
#50 |
Shloooooong bed member #2
super work. Jeff
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
