05-18-2009, 10:13 PM | #26 | |||
Re: Score!!
I believe it is the '73 350 Quote:
easy come, easy go THANKS GUYS!!! Think I will pull the pan and valve covers this weekend and see if it is a 2 or 4 bolt and what heads are on it. I want to build me a break in stand so I can run it out of the truck to see how it sounds....we will see
CHEVY ONLY |
05-19-2009, 12:45 AM | #27 |
60-66 Nut
Re: Score!!
In building a 383 you can use the 5.562 rods from a SB400 with a stock 350 piston. However this leaves a bit of extra piston to deck height......I don't remember just how much. I would just use the 5.7 rods from the 350 and get a set of 383 pistons. They aren't that much more than a good 350 piston since 383's are so common these days.
05-19-2009, 05:36 AM | #28 |
Hey Y'all!!
Re: Score!!
If you wanna spend the $$ on rods, go ahead with some 6" ones. That puts less side load on the piston and there were some other reasons too but I'm kinda fuzzy headed right now...
Of course, with the 6" rod, pistons are a definite must. As far as a stand to put it on to crank it, don't you have a frame sitting around somewhere with nothin' on it???
Just hopin' I live long enough to finish something!!! |
05-19-2009, 07:24 AM | #29 | ||
Re: Score!!
hmmm... I will have to do some research.. yeah I have the frame, but it is completely bare, guess I could slap the front cross-member back in it to fire it up though good idea Tim!!
CHEVY ONLY |
