Old 05-19-2009, 02:18 PM   #26
tekno62
Re: Brake problem – cant lock them up
anyone know where to get that little tool cheap? the ones I have found on the net seem to cost alot.
tekno62 is offline   Reply With Quote
Old 05-19-2009, 02:19 PM   #27
tekno62
Also I found this link on bleeding the brakes.
http://jeepgarage.free.fr/OWN/brake%...20bleeding.pdf
Old 05-19-2009, 02:24 PM   #28
lyrikz
PITbut
lyrikz's Avatar
Thats on a jeep. Everyone seems to have there little different things...
What year and make is your rig.. I will get you your exact procedure.
New project. 1971 Twin Turbo blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=676047
My new YOUTUBE channel.. Videos of my truck and a current walk around.
Lyrikz74 Youtube channel DONE! SOLD!
My 1971 stepside build thread
My Build Thread UPDATED 6/11. DONE
and sold.
lyrikz is offline   Reply With Quote
Old 05-19-2009, 02:30 PM   #29
tekno62
I have a stock 72 350/350 disc on front and drum on rear. the brakes are all stock and everything has been replaced.
Old 05-19-2009, 02:33 PM   #30
lyrikz
PITbut
lyrikz's Avatar
Ok, then wha tyou want to do is crimp that pin off like cdowns said and you want to bleed it like this for a 72
Now if you have a 1970-1974 the bleed procedure is.
LF, RF, LR, RR.....
Let us know how that works...
and sold.
Old 05-19-2009, 02:55 PM   #31
VDOG
Grand PooBaa Member
VDOG's Avatar
Cant we all just get along. Combination Valve is what came on our truck that had drum and drum. Prop valves were disc and drum.
I know cause thats what I had before I converted to disc brakes in the front.
VDOG is offline   Reply With Quote
Old 05-19-2009, 03:05 PM   #32
lyrikz
PITbut
lyrikz's Avatar
I wasnt arguing what it was called, i just wanted to make sure we were talking about the same valve. I snapped at someone, and cdowns resnapped at me.. No biggie...
Its good, just want to make sure he gets helped right.
and sold.
Old 05-19-2009, 03:10 PM   #33
berencam
berencam's Avatar
Assuming by some strech the master was bled, by bleeding the entire truck, you may have old rubber hoses that are ballooning up when you press the brakes, thus not giving the force to the pads.
69 chevy c10 350 3 speed manual wood bed build thread here r.i.p.
70 c10 auto 350 build here
berencam is offline   Reply With Quote
Old 05-19-2009, 04:11 PM   #34
tekno62
Hmm I havent changed the rubber. But with more work then I know what to do with its going to be a few weeks before I could replace them. I know.
Old 05-19-2009, 04:28 PM   #35
berencam
berencam's Avatar
Oh and when you buy a new master there is usually a bleed kit with it, there is two caps that go into the outlets, I never 'bench bleed' on a bench, i install the master then leave the lines unhooked, and bleed in the truck. If you have a show truck i wouldnt recommend this because it will eat the paint, but if your truck is old and rusty, just catch the fluid with a cup when you bleed it.
Old 05-19-2009, 04:37 PM   #36
69GMCLonghorn
69GMCLonghorn's Avatar
I hate to bring this up as it's kind of a cop out, but in a situation where the brakes are giving you problems, hunt down a good brake shop that will "power bleed" the system. Don't ask me exactly what they do. I think they hook something to all 4 wheels, open the valves and push fluid up the lines, but I'm not sure. All I know is when I had it done on my truck when I had a problem, the pedal DOUBLED in firmness. It didn't cost very much either ($30?).
69GMCLonghorn is offline   Reply With Quote
Old 05-20-2009, 10:00 PM   #37
tekno62
thanks for the idea. I'll look into it. I dont have alot of time and doing a raod trip Friday. been working 14 hour days. most of the time I have been posting at work.
