#26 |
Re: Gas milage: 6cyl vs. 8cyl
My 68 C10 with 292 got 12MPG. My C2500 with 402 gets 10.
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
#27 |
Both are basically air pumps. They take air in, mix with fuel, add a little spark and pump it out. There are dozens of factors affecting fuel usage on trucks. Rolling resistance (big tires = resistance to roll). Wind resistance (big mirrors=wind resistance). Engine size (big=more consumption). Transmission efficiency (more gears correctly used =better use of power). Rear end ratio (best fitted to usage ie 411-1 good for stump pulling or heavy trailer towing while 308 are fine for highway with 342 or 373 a happy compromise). Tune up efficiency (dirty carb can cost you 3-4mpg easy!!)--Old plugs, wires, points ignition===all tend to rob mpg.
And probably the easiest fix is to drop a big hammer on your right foot as driving habits are a major influence. My 72 ---I installed a new crate 350, 5speed trans, 308 posi gears, HEI ignition, Edelbrock 1406 carb, slightly oversize tires---and could get 20mpg flat highway. Installed an edelbrock intake and actually lost 1-2 mpg--went back to stock small/large intake and regained my mpg. Went to hooker headers and lost 1-2mpg--went back to ram horns and regained. Lesson learned is that not all modifications are an upgrade to performance. Expert engine rebuilders will confirm that heads and cams do more for engine performance (power and economy) then external crap but I'm cheap so I tend to do the simple and then measure the crap out of that. I have personally driven a 72 Blazer with 350, auto and tons of miles and got 16mpg which is not typical so tune em, tweek em, upgrade em, and keep your foot out of them unless necessary and you will improve your mpg. Huck |
#28 |
A 20 mpg 350 chevrolet!! especially with a AFB!!WOW that sounds kinda like a unicorn to me.... as in I've heard of em but never witnessed one personally! I do agree that a 1406 will do better on gas than a crappy Q-Jet, but a good Q-jet, which has smaller primaries to begin with, should do better on gas IMO, than a 1406 out of the box, and anything will do better than a Holley, short of having a short man sit on your inner fender pouring gas down your intake!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... ![]() 71 ![]() Last edited by UltraBlue71; 05-29-2009 at 02:07 PM. |
#29 |
Moderator
![]() Join Date: May 2007
One word: negligible.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#30 |
If your asking the difference between the two you should probably get a different car
#31 |
68 c-10 250 6cyl 3spd 3.73 rear gears. The best it ever got was 13 mostly 10-11
James '68 Stepside (ground up in progress) My 68 build thread http://louisianaclassictruckclub.fre...side-t956.html '81 SWB "Pap paw" (Driver) The 81 build thread http://louisianaclassictruckclub.fre...-swb-t960.html Member of www.louisianaclassictruckclub.com https://www.facebook.com/groups/296290610747732/ |
#32 |
AGREED go buy a S-10 with a 2.5 to drive during the week and fart around in your 67-72 truck if your worried about MPG's! I just wish mine to have AC (to make my MPG's even worse) man its getting hot around here!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... ![]() 71 ![]() Last edited by UltraBlue71; 05-29-2009 at 03:47 PM. |
#33 |
72 C-10 SWB Stepside - 454HO/Holley 750 - 8-10MPG or less if I'm in it
#35 |
![]() ![]() but I love my BBBBRaaaaaaaaaaaggggggggghhhhhhhhh! ![]() ![]() 1970 350/400 3.73 |
#36 | |
![]() Join Date: Jan 2009
![]() ![]() ![]() ![]() ![]() ![]() I got around 9 with my 350/350/3.08 and my foot in it best with the 350/350/3.08 was 12.5 but it I put in a 700r4 in it and the motor blew (I think it had something to do with my lead foot) and I'm waiting on a 383 to see how the mileage tests go,
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
#37 |
Before I had a 454 and TH400 in my 69 c10 LWB I had a 250 6 popper that I rebuilt with an Isky supercam. Best mileage I ever got was 16.5 mpg going 60-65 and hangin with the semi's on I-5 between Bakersfield and Redding CA. This was with 3 speed on the column and 3.73's. I never re checked that combo but I would guess 12-13 on a typical 2 lane mountain hwy. The 454 that is in it now averages 9.5 hwy with TH400 and same 3.73's. In town seams to be around 7. My dad owns a 70 c10 with a stock 307, 3speed manual, 3.73's and claims 15mpg. He is also 70 years old.
#38 |
Gotta ditch the holley.
#39 |
God Bless Mr. T
'65 GMC
283 2 barrel 3.07's SM420 235 series tires Best was 15 MPG combined city/highway Average around 12. Keep the RPM's down and don't romp the throttle. Ease into it and it can be done. Living in a rural area really helps. I can't imagine it would be nearly as easy in cities.
Like a midget at a urinal...sometimes you must stay on your toes. |
#40 |
'72 402 Big Block, TH400 9mpg
'90 4x4 built 350, 5spd 14mpg '90 Ford Van l6cyl, C6 15mpg '04 Grand Prix GT v6, OD 24mpg |
#41 |
Green club
In my case, it did not matter if I had this Holley or the Q-jet it was about the same.
I have tried different jetting/rods, power pistons etc and could not squeeze better than 15 or so on the freeway. I have accepted the fact that these trucks are rolling bricks and will not get better mileage with a carb'ed engine ![]()
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln Last edited by 67shortie; 05-31-2009 at 05:10 AM. |
#42 |
you should be ok with the right rear gear is a big help too
#43 |
Factory Strippers Rule!
![]() Join Date: Mar 2009
How about you 5.3 and 6.0 ls swappers? What kind of mileage are you getting? My 250/PG/3.73 Short Fleet got 12- but it was struggling to go 65 downhill, so I sold it. Wanting a serious 6.0 to replace it soon with an overdrive auto.
#44 |
I have a 355 with edelbrock 600 and NV3500 with 3.08 gears. I got 12.25 the first tank and 12.95 mpg after I rebulit the dist. Driving about 50/50 city/hwy. I am going to work the carb some more and see if I can get into the 13's. I babied it too.
#45 |
beer me
![]() Join Date: Jun 2009
since were on topic i was wondering how good a milage that a 400 sb will get with an edelbrock 4 barrel q jet
![]() 1986 f150 1986 silverado-my dads truck that i'm fixin up ill keep my freedom my guns my money my religion and you can keep your CHANGE-hank williams jr |
#46 |
Since my fuel gauge is erratic, I top off the tank every time I hit the pump and keep up with my miles to make sure I don't run out. That being said, I consistently run 11 mpg--to a tee. GM crate 350, edelbrock carb, TH350 trans, 4.10 gears, 31" tires.
'72 3/4-ton 4x4 LWB--my daily driver |
#47 |
Big Red - Now its a SWB!
my 68 3/4 ton gmc had a 305 v6, then a 351 v6, with 4.10's and a four speed w/granny. It always got right on 12 mpg no matter on the hiway or in the city. waiting to see what it gets with the 355 sbc w/holley 670, edelbrock intake, 268 comp cam, headers, 10:1 comp, etc.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#48 |
They both get bad mileage. I would get better mileage if I drilled a hole in the gas tank and rolled the thing downhill. 292.
