Old 07-29-2009, 06:11 PM   #26
1LoC10
Insert Title Here
1LoC10's Avatar
Re: Bagged 05 Suburban
looks good
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 07-30-2009, 08:00 AM   #27
tvblazer78
Low & Fast!
tvblazer78's Avatar
Sweet! Let us know how it drives and looks out side in the sun..
tvblazer78 is offline   Reply With Quote
Old 07-30-2009, 08:05 AM   #28
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Glad to see you are getting things buttoned up; can't wait to see some road shots.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-30-2009, 08:12 PM   #29
LooseCannon
Thanks!
LooseCannon is offline   Reply With Quote
Old 08-03-2009, 05:44 PM   #30
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 08-13-2009, 11:11 AM   #31
LooseCannon
To center the rearend the panhard bar needed lengthened 1/4".
Cut the bar
Lengthened 1/4" and tac welded for fitment. Installed the bar and raised the rearend to ride height and measured. The rearend was centered within a 1/32 so pulled the bar back out and started making the plates to weld over the 1/4 gap.
Bending the front plate
Making a pattern for the back plate
Transferring the pattern to flat stock
Pictures didn't turn out but they show the plates welding to the bar
Front plate
Back plate
Old 08-13-2009, 11:17 AM   #32
LooseCannon
Also started making the mounts for the air tanks, compressors, and valves. The plan is to install the air management system between the frame rails where the spare tire was.
Showing the panhard bar and one of the mounts clamped for fitting
Starting to look like something
Tac'd together for fitting. Everything checked out so tomorrow I'll remove the tanks and finish welding
Old 08-13-2009, 01:27 PM   #33
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Awesome craftsmanship! It's just a shame we won't be able to see it after it's slammed to the ground.
-Nate
Old 08-18-2009, 10:21 AM   #34
tvblazer78
Low & Fast!
tvblazer78's Avatar
Very cool! And do you have AC in your shop I think you do and if you do you suck!!
Old 08-18-2009, 03:14 PM   #35
LooseCannon
I have heat, but no ac. maybe next year
Old 08-18-2009, 03:31 PM   #36
67ChevyRedneck
67ChevyRedneck's Avatar
Coming out really cool!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-02-2009, 05:40 PM   #37
LooseCannon
Found time to make a little more progress...
Completed the air management rack for the tanks, manifold and compressors. I'm happy with the end result - clean, functional and compact.
View from underneath (hard to get a good pic)
With all of the components mounted.
Needed some extra room so I removed a portion of the floor cross member. Drilled out the spot welds (WHAT A PAIN) and cut the rest with a cut off wheel. (I accidentally deleted the last pic of the piece completely removed but you get the idea
The air lines along the frame rails are installed- still need to connect to the tanks.
Currently I'm determining where to mount the height sensors. Looks like this is the best approach for the front. Still need to fab a mounting bracket and secure it to the A-arms. The A-arms are cast and I don't have a brazing torch so bolts will be used to secure the bracket to the A-arm.
Amount of sensor arm travel.
Old 11-02-2009, 06:48 PM   #38
my67chevytruck
Under Construction
my67chevytruck's Avatar
nice work!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 11-02-2009, 08:36 PM   #39
tvblazer78
Low & Fast!
tvblazer78's Avatar
Ya that is nice work!
Old 11-02-2009, 09:19 PM   #40
ratty 46
Looks as if you don't let anything slow you down. Great progress & install looks clean.
Ratty 46
ratty 46 is offline   Reply With Quote
Old 11-05-2009, 06:49 PM   #41
SkylineNXS
SkylineNXS's Avatar
That thing looks awesome, i must say. I personally like the way u showed the height sensor travel, exposure is a beautiful tool. I was just wondering, as someone mentioned above, that the upper shockwave mount may be weak. If im right, that was the old shock absorber mount correct? and then the torsion bars would take more of the load? Im wondering if anyone knows if this is structurally as strong as with the torsion bars? I am thinkin about doing this similar operation to my 00 sierra, and would love to be able to just throw the bags in there and take out the blasted torsion bars.....thanks
again very nice work....
BRAD
2000 GMC Sierra EXT Cab Short 4x4, finally mine...
1966 C10 SWB Fleet, 250 I6, three on the tree....
Previously Owned....
1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4....
1972 Chevy LWB Fleet 350/350
EXTENDED CAB ALL THE WAY!
.._..~...-...._...____
.._..-...______|_|__\____
..-..~.|_(O)__|_|__|_(O)]
SkylineNXS is offline   Reply With Quote
Old 11-05-2009, 11:59 PM   #42
LooseCannon
BRAD
Thanks! The shockwave mounts to a U shaped bracket and the bracket mounts to the original top shock mount.
You do bring up a good point about the bracket and shock mount taking on a lot more of the load with the torsion bars removed. I trust in Air Ride Technology's R&D department and that the bracket and mount will hold but I will keep an eye on it.
Not sure what bag setup you're going with... If using convoluted bags you may find this interesting:
http://www.fullsizechevy.com/forums/...-02-tahoe.html
Good luck!
Old 11-06-2009, 01:55 AM   #43
Frizzle Fry
Frizzle Fry's Avatar
Subscribed. I had a 2001 Tahoe I wish I could have done this to. Nice work!
Frizzle Fry is offline   Reply With Quote
Old 11-07-2009, 04:48 AM   #44
sams60gmc
sams60gmc's Avatar
Awesome looking ride man! I wish I could bag my Yukon!
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 11-09-2009, 01:03 AM   #45
SkylineNXS
SkylineNXS's Avatar
hey thanks, appreciate the link, most certainly helps out. Only problem with my truck is the fact that its 4wd, so bag clearance issues arise, so that blows. I did come across this pretty nice site that has basically an assembly guide for a good number of vehicles on it, if anyone needs somethin like this, for free anyway....
http://www.compnine.com/index.php
Brad
Old 01-06-2010, 01:06 AM   #46
VA72C10
VA72C10
VA72C10's Avatar
Any updates with this out of the shop? Saw the link in your other build...Nice work on the install. Seeing the clean fab work here shows that the 68 will be sweet!!!
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-07-2010, 12:36 AM   #47
LooseCannon
Thanks!
The front sensor arm bracket, where it mounts to the lower A-arm, is now complete.
Tacked it in place and snapped a center line.
Drilled and tapped two mounting holes.
Trimmed and rounded the corners and secured with 1/4 20 bolts.
Now the front is complete! Next is to mount the rear sensors...
Old 01-07-2010, 01:16 AM   #48
VA72C10
VA72C10
VA72C10's Avatar
Very nice. I'll be doing those sensors soon on my chassis for the Accuair setup.
Old 01-07-2010, 01:53 AM   #49
70k52wd
Blaze-Air
70k52wd's Avatar
Nice build. I like the take off rims. How close to the inner liners are you? What dia tire, size?
70k52wd is offline   Reply With Quote
Old 01-07-2010, 02:59 PM   #50
LooseCannon
265/60/18's with about a fingers width between tire and inner fender well when aired out.
