Old 01-04-2003, 01:20 AM   #26
lotik
drag it like you stole it
stock floor. 2x3 box tubing under the cab and reinforced. bedfloor raised in rear, core support lowered into frame. cut out holes in the floor for transmission. BTW, new 350 crate and new 700r4 are in. not too much longer.
negative camber //LA\\
lotik is offline   Reply With Quote
Old 01-04-2003, 01:25 AM   #27
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Did you have to raise the tranny hump after the B-drop?
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 01-04-2003, 01:28 AM   #28
lotik
yes, but i did have a low tanny hump, so i dunno about a high hump (if that applies to you).
Old 01-04-2003, 01:31 AM   #29
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
yea I got the low hump too. Any pics of the hump, and how far did you raise it? Just cut and piece it in?
68 chevy money pit
51 chevy belair
95 Honda 900RR
Old 01-04-2003, 01:34 AM   #30
lotik
actually its still just a hole. i had to get the tranny in there so i could see how the sheet metal need to be fitted. i am probably going to just rivet some metal in since it will be covered. i also had to cut two small holes for the frame to come through at the front where the cab sits down in the frame. i will get a pic tomorrow to explain better.
Old 01-06-2003, 11:18 PM   #31
Chevy_68
Chevy_68's Avatar
bad truck post some pics on the hole process of the body drop of course. keep up the good work
Chevy_68 is offline   Reply With Quote
