Old 06-06-2009, 12:50 AM   #26
AusMarty
Re: I finished My custom dash
Originally Posted by big mike71 View Post
How are your brake and gas pedals set up, is the brake pedal to the right or the left of gas pedal. Do you use your left foot or right to drive. Sorry for all the questions just curious.
Mike, the gas pedal is on the right and brake on the left, so it's still the same as you guys
AusMarty is offline   Reply With Quote
Old 06-06-2009, 12:58 AM   #27
71chevytruckguy
71chevytruckguy's Avatar
that's really nice. lookin forward to more pics. chris
its a work in progess.
71 c-10 lwb, in the middle of frame off restoration.
69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump.
7.807 @ 88.37mph 1.60 60FT
80 g-20 van, tow rig, cammed 305, th350, 10 bolt
88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's
71chevytruckguy is offline   Reply With Quote
Old 06-06-2009, 02:51 AM   #28
Lippyp
English Chevy Owner
Lippyp's Avatar
If its setup normally then its exactly the same as you, gas pedal to the right then brake then clutch to the left if its a manual.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
