#26 |
Wheelin' and Dealin'
Re: operation daily driver... my new 64
man torch red and a metallic black looks killer thats what i did with all my accessories i was toying around with the idea of painting the sides and front of my hood red with the raised part metallic black with silver pinstripping on the V
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside ![]() Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears ![]() ![]() my build thread: ![]() http://67-72chevytrucks.com/vboard/s...=1#post2601700 |
#27 |
DDOV
ok.. blasting is done.. figured id try my hand at welding.. started off a little rough and burned through just about EVERYTHING.. but finally got the voltage and wirespeed right and i think im gettin the hang of it.. by no means a pro yet.. im learning.. goin to finish welding up pinholes and spray the bottom with bedliner in the morning. pictures to come later..
If you don't like the way I drive, stay off the sidewalk http://67-72chevytrucks.com/vboard/s...d.php?t=317070 The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself? |
#28 |
SSN 706
A lot of times the reason your burning through is because the metal is so thin from the rust. When you get to good metal it won't burn though as easy.
#29 |
Resistance is Futile
Or if you grind too much to clean up the metal it will do the same thing.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#30 |
DDOV
alright i havent posted in a while.. i have lots of updates..
i finally finished the underside of the cab. slip on supports welding up 4spd hole, a few patch panels here and there and got it bedlined. i set cab on the frame.. and epoxy primered it. its now at my buddys paint booth prepping for paint.. more pics to come
#31 |
that is some sweet progress!
#32 |
DDOV
after talking it over with some friends we came up with the idea of making it my yamahauler.. so we decided to go with yamaha blue. here are some before during and after pics
#33 |
DDOV
picked up a bunch of parts today as well. but these are the only ones i could get pictures of right now..
cab trim and grill
#34 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I like that blue.....looks good
![]() So you are going with black trim?
#35 |
DDOV
yea, im not a huge fan of chrome. so i figure black will do the trick..
however, huge setback today. apparently the catylist we used with the clear was no good. and it didnt dry. so while we were cleaning the shop and a freak rainstorm came, it ruined it. waterspots everywhere.. so.. off to the sandblaster again ![]()
#36 |
60-66 Nut
WOW that sucks! sorry to hear that.
#37 |
what did they use for the 5 lug conversion......
#38 |
DDOV
the numbers came up as a 87 i believe
#39 |
DDOV
update.. we decided to see if the clear would dry over the next day or two.. and it is looking promising.. the waterspots are mostly dissapearing, and because it is to be a daily driver, and it is only the firewall... and since we are on a deadline.. we are leaving it. so the z-bar bracket, motor, and trans went in today.. pics to follow
#40 |
DDOV
#41 |
DDOV
#42 |
![]() ![]() Join Date: Jul 2002
Truck looks good!
#43 | |
DDOV
#44 |
Came out nice. I see a future driver enjoying
