Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-16-2009, 11:47 PM   #26
vegaschevy
Re: BBC Chevy 454 and what tranny?
Originally Posted by Rodms View Post
No just have the right cam and converter and tranny,some cams are to much to idle in a street ap,don't think I'm talking you are doing something that is hard to drive down to the sonic without turning it of at the traffic light
well what do you suggest? that was the whole point of this thread
It will not be a daily driver however it will be driven a lot I am not afraid to drive a nice high HP truck
vegaschevy is offline   Reply With Quote
Old 06-17-2009, 02:12 AM   #27
Outlaw72
Hay Team!!
Outlaw72's Avatar
Vegas....the cam you have picked out is very streetable. Nothing at all wrong with it. I just built a solid roller pump gas 496 with afr heads and victor jr intake. The cam has 260 degrees of duration @ .050 and the 3000 stall I have will work just fine. Idles fine at about 900 rpm. You will more than likely break the 500 - 525 hp barrier with some decent heads.
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 06-17-2009, 11:05 AM   #28
vegaschevy
I never picked out a cam
I have a bare block ready to be built up to 500-550 HP.
I just need a parts list on what is good.
Old 06-17-2009, 11:28 AM   #29
Outlaw72
Hay Team!!
Outlaw72's Avatar
Sorry....I misread one of the posts. Everyone has their different opinions on what parts are "good" so I will list my combo and you can use it as reference. I feel that my parts are plenty "good"
SRP 212157 pistons. 496 6.385 rod 18cc dome about 10:1 with 118cc chamber head. This could vary depending on head gasket thickness.
Eagle h-beam rods 6.385.....floaters
Cat 4340 forged crank 4.25 stroke
Custom grind solid roller....basically max effort with street manners and 3,000 stall
Billet steel double roller timing chain
AFR 305 as cast heads
Victor 454R as cast intake
I cannot remember the year on the block but it needed no additional clearance work for the stroker
Line bore and stud the mains 2 bolt
Bore and hone with torque plates
Square deck
Due to the line bore...I had to buy a timing chain that was .005 shorter than normal. Should make between 650hp and 680hp......maybe more maybe less i dunno. I built it to run nitrous so the hp numbers mean nothing to me.
