Old 01-05-2003, 10:41 PM   #26
Izzy
Trucker.
Izzy's Avatar
Originally posted by low 84
no thats not his, his isn't that clean under the hood
there really isn't a reason to bodydrop our trucks, the lowest part is the crossmember, if you get an aftermarket crossmember or make one like chris you should be able to lay the body without a body drop
What he said.
You'll have to make a flush mount tranny member and notch all the crossmembers above the driveshaft but I'd imagine if you can do this you'll have no trouble with the rest of the minor details.
Izzy is offline   Reply With Quote
Old 01-06-2003, 02:32 AM   #27
low 84
low 84's Avatar
Originally posted by fiveeightchevy
What he said.
i wonder who i learned that from
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 01-06-2003, 09:19 AM   #28
Izzy
Trucker.
Izzy's Avatar
BTW that new setup is 1k with uppers, lowers and a new crossmember.
Old 01-06-2003, 09:21 PM   #29
low 84
low 84's Avatar
what setup? the fatman one? thats not too bad, but still i'd rather put 1k into my new shortblock
'05 1500 Crew Cab
RIP
Old 01-07-2003, 09:36 AM   #30
Izzy
Trucker.
Izzy's Avatar
Yep the fatman.
I'd also rather put the money into something more useful like bodywork and paint.
Old 07-15-2013, 08:43 PM   #31
A.C.E. Graphics
Re: Crossmember How to Page is up...
so if i take the 1.5 out mine like you show will it lay frame without the a arms or the the belly of the crossmember hitting ive got a 71 c10 and i havnt yet measured but im wanting to lay frame but the front is keeping me from doing that. will your chop of the member be enough to lay frame without front hitting first.
thanks and good post
also what about the upper control arm mount it will have to move up also and it looks like there will be nothing for it to bolt to on the frame.
also will you have to trim the a arms at all
A.C.E. Graphics is offline   Reply With Quote
