#26 |
Grand PooBaa Member
Re: What is your engine setup?
Just a slightly built 283 ci with a cam thats way to big. Edelbrock carb and Weland intake manifold, Accel HEI, and Headman headers. Going to be swapped for a slightly modified 350 with 190/202 heads and changing my rearend from 3:08's to either 3:55's or 3:73's
#27 |
On the college boy budget...
Stock GM Performance Parts 290 hp crate 350. Edelbrock Performer intake with an Edelbrock 1406 carb. Stock HEI. Junk headers. Does alright for now, long term plan is to slap some Vortec heads on it, go to a roller cam and put some decent headers on it. Maybe a 625 Demon carb as well. Who knows when all that'll actually happen though.
-'68 C10 short/step- 350/350 |
#28 |
For now, stock '05 5.3L with F-body headers and cold air intake. Keeping it in it's stock configuration just to get it up and running. Then I'll throw on a LS6 intake manifold (already have) and a cam (undecided at this time) as well as a new torque converter.
Then when I financially recover from the intial build, I'm going to bore it out to 5.7L and rebuild it with forged internals and top it off with a kenne bell supercharger ![]() |
#29 |
Because im senior in high school, dont make much money part time, heres my budget 87 TBI 350 converted to carb, edelbrock performer intake, holley 600 vacuum secondary, headman long tubes, MSD Distrib and wires. 2 inch carb spacer
1978 GMC Jimmy 454bbc Turbo400 NP205 3.73 gears 4inch lift 33's |
#30 |
383, Scat rotating assembly, performance heads, .490 flat tappet cam, Edelbrock intake and 750 carb, Accel HEI, Hedman Headers
Change- better heads (aluminum maybe?) bigger, roller cam
'69 Chevy C/10-under reconstruction -- '68 C20 Camper 50th Anniversary-runs, but sorely needs a resto --
'07 Cobalt SS/SC-very fun DD -- '93 Chevy K2500-LQ4/4L80E swap -- '84 Trans Am-awaiting (LS) drivetrain -- '00 Trans Am-road tripper -- '06 Z06-577 WHP beast |
#31 |
Just Not Low Enough!
67' Impala 327 w/ longtube headers (unknown brand) holly intake and holly 600cfm carb. Procomp noisy gear timing set (want to replace, gets annoying)
GM 80's HEI. Building 383 out of GM 84' 4 bolt main block.
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd ![]() Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. Last edited by BAGNDRAGIT; 06-11-2009 at 10:05 PM. |
#32 |
468...12.2:1 forged pistions, studded top and bottom....comp cams valvetrain..664 lift, 256@.050, roller. fluiddamper balancer, merlin heads, 2.30 pro-flow valves, ti retainers..eddy rpm intake, holley 950 cfm ultra hp carb, complete mds ignition, all balanced etc...t-400 tci guts, 3500 stall...3.73 rear diff, locker. pulls nice.....lookin at a 511 stroker kit and a 4l80e over the winter, drop the comp to 10.5 to one and a 4th gear for those road trips...build em to drive em!!!...
#33 |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
454 .030 over, Keith Black dome top pistons, Lunati 60202 cam, RPM Air Gap, HEI, 781 heads, Demon carb, etc...
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
#34 |
383 stroker, .030 over, 3/4 race cam, milled 882 heads, stealth intake, carter 750cfm, hooker super comps
#35 |
Stock Goodwrench Crate 350, 240HP, sometimes if I'm feeling froggy I intall the stock aircleaner lid upside down, just cuz I can, I bet that makes it at least 241-242hp
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... ![]() 71 ![]() Last edited by UltraBlue71; 06-11-2009 at 10:50 PM. |
#36 |
![]() Join Date: Apr 2005
383 stroker with a Vortec Supercharger, Holley 750 carb, Dart II aluminum heads, roller rockers, roller cam, all forged parts, internally balanced....dyno 440hp on bare motor, 620hp on low boost, 675hp high boost....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#37 |
mines just a 327 with corvette cam, crank, manifolds, pistons, intake,ect. with a 600 edelbrock
1972 longbed- 454 1967 shortbed- 355 |
#38 |
Green club
A 'lil 9.5/1 355 with Patriot vortecs, Voodoo 60202 cam, performer/1850 HEI and headers. Runs decent, can only puch this sucker in 2nd gear, 1st goes spinning every time from a roll
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
#39 |
I put the details on my previous post but since eveyone is adding picts I thought I would do the same
![]() She is all show and go ....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 06-12-2009 at 09:04 AM. |
#40 |
I have a stock internal 5.3 LSx. With this engine I would swap out the cam and maybe adding alittle nitrous for the track.
Down the line I would like to build a 402/408 stroker using a 6.0/6.2 block, 4.00" stroker crankshaft, a lumpy cam, and a decent set of heads (LS3/L92 heads will work).
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
#41 |
![]() Join Date: Jan 2008
Hey Big Al, How do you stop that thing with no power brakes?
#42 | |
![]() I am going to to a wildwood four wheel disc set up when I redo my suspension. I am just trying to work my self up to take it back in the shop and start working on it.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 06-12-2009 at 11:16 AM. |
#43 | |
#44 |
Grand PooBaa Member
#45 |
I built it
454 in sig. 750 edel. performer intake. torque monster
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
