Old 06-12-2009, 10:48 PM   #26
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: Bondo Louie
The abrasive disc that was mention above work good also. I find wire wheel works great for bondo remove not so much for paint and rust. The disc mention about will work great, but get expensive after a while. Rather you go with the wire wheel or the abrasive disc I would use aircraft stripper first handle most of the paint removal for a whole bed side.
Kabwe is offline   Reply With Quote
Old 06-13-2009, 01:22 AM   #27
tim21391
tim21391's Avatar
Re: Bondo Louie
im suprised it didnt split out over the years
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 06-13-2009, 01:35 AM   #28
allen123
It'll buff out
allen123's Avatar
Re: Bondo Louie
I thought mine had alot! wow lol
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
Old 06-13-2009, 05:06 PM   #29
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Bondo Louie
Originally Posted by BADSAM View Post
Am I the only one impressed that the bondo lasted 20 plus years ...
You had to use a hammer and chisel to get it off, it didn't fall off!
I wonder how much longer it would have lasted?
Yes your the only one, im still in shock to see exactly how much was on there.
There are 3 inch long screws that were and some still under the bondo screwed into the bedside and tail light area. I guess to help keep the bondo on the truck
VDOG is offline   Reply With Quote
Old 06-15-2009, 03:59 PM   #30
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Bondo Louie
The first picture is clean up from a flap disc on my 4 inch grinder.
The others what I cleaned up with a wire wheel after the flap disc. from what I notice the flap takes off more bondo quickly then the wire wheel.
And as thick as it is on my truck im going to stick with that then clean up with the wheel. Any thoughts?
Old 06-16-2009, 11:31 AM   #31
OLDIRON69
Re: Bondo Louie
Get ya a bedside and be done with it. That is not worth fixing.. IMO
05 2500HD 6.0 excab
69 LWB-Gone but not forgotten!
68 Dodge Charger 383/727
69 Dodge Charger-440/4spd
OLDIRON69 is offline   Reply With Quote
Old 06-16-2009, 11:43 AM   #32
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Bondo Louie
I agree, the prices im finding are so high, it makes me not want to pay for a bedside. Finding one in the junkyard thats not damage is the other problem.
Old 06-25-2009, 02:15 PM   #33
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Bondo Louie
Uncovered more pink stuff!!
Anyone got a bedside they want to donate?
Old 06-25-2009, 02:27 PM   #34
OLDIRON69
Re: Bondo Louie
WOW...for the amount of time and filler they used, could have bought a good used LWB...
05 2500HD 6.0 excab
Old 06-25-2009, 02:33 PM   #35
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Bondo Louie
You got to remember this was done back in the early to mid 80's.
And my back then who really worked on metal, filler was the way to go.
You should see the dust. If you notice in that area I still have not gotten to the metal yet.
Old 06-25-2009, 03:50 PM   #36
UltraBlue71
UltraBlue71's Avatar
Re: Bondo Louie
Back before stud guns some guys would drill holes and use a screw in a slidehammer to pull the dents, then weld the holes shut, well looks like we skipped that last step, wheres my tube of red hardener!
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG...
71 LWB
UltraBlue71 is offline   Reply With Quote
Old 06-25-2009, 07:15 PM   #37
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Bondo Louie
I pulled out at least 12 screws, and cut the heads off of bout 10 more.
