#26 |
#16876
Re: Fuel regulator mounting
It's a phenolic spacer. It's supposed to keep the fuel cool.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
#27 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I do like this setup.
(Obviously, I'd only need a single line to carb)
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#28 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Sorry Robert. I did take a couple pics, but I left the dang memory card at the shop when I came home
#29 |
Registered Truck Offender
A couple of thnings,, first those pictures of the regulator mounted on the firewall,, TABOOO, Bad, No No NO!!!
NHRA tech says specifically the the regulator and all connections must be mounted 6" forward of the bellhousing / flywheel. No if, ans, or butts ![]() Also an accumilitive MAXIMUM of 12" of rubber line in the entire fuel system, from tank to carb. If your never going to the track, this means nothing. HOWEVER... rules are made because someone was hurt or killed. Good enough reason for me to not mount the regulator on the firewall. And just a quick mention about the spacer,,, A 2" spacer like that is 'properly' used to raise the effective rpm range of the motor. (likewise hurting LOWER RPM torque)
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
#30 |
60-66 Nut
Here are the pics of one I did not long ago. I had to make the fitting between the carb and regulator. I made up a short piece of 3/8" line with a double flare on one end and silver soldered it to a drilled out reducer bushing that fit the outlet on the regulator. This was so I could position the regulator where I wanted it while still being able to make a tight connection at the carb. I could not find a fitting like that to buy, so I made it.
#31 |
^ Thanks
I didn't think of coming straight off the carb with the regulator/gauge. I'll be plumbing mine in the coming weeks. I'll post pictures when done.
#32 |
Another I found.
#33 |
#34 |
60-66 Nut
That should work as long as there is room for it. The one in the pic I posted, there was not room to run the fuel line any other way, due to the design of the intake manifold (440 Mopar).
#35 |
I have my regulator mounted on the passenger side of the carb, with an aluminum bracket from jegs that i had to machine to get it to work with my regulator because it is a barry grant.
heres a pic. |
#36 | |
It's Better With Nitro
I typically mount my fuel pressure regulators with rubber isolators, or leave them supported by the fuel lines (this is how my regulator is mounted in my Super Gas car). Here is a photo of my regulators mounted in my truck...both are mounted with rubber isolators... ![]()
#37 |
Grandpa in the rustmobile...
Bump this is a great thread.
I have an edelbrock carb rpm intake. I need to put a regulator and maybe a guage in my system. I dont wanna spend $40 on a pre assembled (but nice) edelbrock line. Looking for brake line clean on an edelborck with a regulator LETS SEE EM
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#38 | |
#39 |
I cheated and bought the edel. reg kit that is a 1/4" thick plate that mounts between the carb/intake and the reg mounts to it..
#40 |
Gotta pic stitch?
#41 |
#42 |
Any installed pictures LOL
#43 |
