Old 04-16-2011, 05:03 PM   #26
forestb
forestb's Avatar
Re: Aftermarket Seatbelts???
That seat looks like it would cost more than my truck is worth and then I would have to by the passenger side. Here is a picture of the nut that the PO welded into the wall of my truck does it look like it will hold?
forestb is offline   Reply With Quote
Old 04-17-2011, 10:49 AM   #27
astrochimp
IMHO welding a nut to the cab side is not strong enough.
I used belts from a 89 Chevy truck, and made mounting plates from 1/8 steel, IIRC 2" x 1.5" (coped plate others sold). I welded the nuts onto the plates. To mount the plates I drilled a hole for the seat belt bolt, and then 2 for 'mounting screws. (added 2 threaded holes in the plate. I dropped a wire in the large hole in the cab, feed in threw the large hole in the plate, and wrapped it around a bolt. Pulled the plate into position, installed the 2 'holding screws, then pushed the wire back out, and installed the belt.
Passenger side I was able to reach the back of the plate!
You also need plates under the floor for those mounts.
Some of the aftermarket belt company's have great "how to's" that show proper mounting and how to locate them.
astrochimp is offline   Reply With Quote
Old 04-17-2011, 11:57 AM   #28
jocko
jocko's Avatar
Here's how I did mine - non-retractable seat belts (and all trucks should have the mounting "surface" - if yours didn't come with belts though, then you'll need to add the backing plate/washer, etc as outlined by others above). Just like some others mentioned, non-retractables fall out onto the ground and it's annoying - so I added a self-retractor, something you could buy back in the day. It's available still through Year One (I purchased these in the Impala catalog, but used them on my truck once I sold the imp). These belts were in the truck, but were installed backwards (note the male end should be anchored to the floor, not the femle/latch end - i.e. the first picture is how it was before it was corrected), so I swapped them around and added the retractors - they work smoothly and, for me anyway, maintained some look of originality as opposed to modern (but very useful and convenient) retractor assemblies. Just one way to skin the cat. Also, a thread below that I referenced for install info that someone passed along to me on this site. 2nd post has a few more pictures - and concur on the comment above - referencing belt mfgrs sites for details - for instance, note the special bolt used to anchor the belts - not just any grade 8 will do - the factory deal is a special shoulder bolt (note that the rubber grommet is only used as an anti-rattle thing, I installed it on the shoulder of the bolt - and since it's only on the shoulder (and the bolt is completely torqued down before the rubber is even engaged means it has no impact on the install, strictly for anti-rattle)).
Installation topic..
http://67-72chevytrucks.com/vboard/s...d.php?t=412985
Old 04-17-2011, 12:01 PM   #29
jocko
jocko's Avatar
a few more pics
Old 04-17-2011, 12:09 PM   #30
jocko
jocko's Avatar
oh yeah, one more thing... Markeb01's absolutely correct, the chrome latches got HOTTTTT!
Old 04-19-2011, 09:52 PM   #31
willyp
willyp's Avatar
just installed these from seatbeltpanet.com
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 04-19-2011, 11:16 PM   #32
broey
Square
broey's Avatar
I just ordered the 3 point retractable seat belts from lmc. I'll let you all know if they were worth the price. I needed black belts and the universal ones online seemed very sketchy and also are not dot approved.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 12-04-2012, 11:03 PM   #33
Vortech
Vortech's Avatar
Looking to pick up a set of new seat-belts. What size 3 point retractable seat belts do I need. What size lap belt do I need for the center? Looking at both seatbelt planet or gobelts.
Vortech is offline   Reply With Quote
Old 12-08-2012, 12:06 PM   #34
bama63
bama63's Avatar
good selection and pricing http://wescoperformance.stores.yahoo.net/seatbelts.html
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 12-08-2012, 12:24 PM   #35
silvertonguedevil
silvertonguedevil's Avatar
There's a lot of good information in here! Keep it going!
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 10-14-2013, 11:33 AM   #36
1963c-10
1963c-10's Avatar
Not aftermarket, but heres some OEM buckles that I restored and had some new webbing added to them. These will be for when I do the interior color change...
My truck did not come w/seat belts, but I did install them. I currently have some GM embossed buckles installed.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-14-2013, 12:24 PM   #37
Fastest32
Fastest32's Avatar
Has anyone taken seat belts out of a 88-98 chevy truck? I got my bench seat out of one and was thinking about going back for the seat belts?
BaBaBooey BaBaBooey
GO SPURS GO!!!
Fastest32 is offline   Reply With Quote
Old 10-15-2013, 12:15 AM   #38
Captainfab
60-66 Nut
Looks good
20 years ago when I put my Suburban together, my ex upholstered the seats for me and also put new webbing in the seat belts.
Old 10-15-2013, 08:27 AM   #39
1963c-10
1963c-10's Avatar
The new webbing was well worth the safety factor. If they were not going to be used, I'd put the OEM/unrestored set I have in, but I do use my seatbelts, so new webbing was a must.
Old 10-15-2013, 11:38 AM   #40
kieth
kieth's Avatar
I just ordered the seat belt retractors from year one, if you google year one promo codes you can save 15%......saved me $5.00 Kieth
kieth is offline   Reply With Quote
Old 10-15-2013, 01:03 PM   #41
1963c-10
1963c-10's Avatar
Talking about these Keith?
Old 10-15-2013, 05:22 PM   #42
kieth
kieth's Avatar
Yes, those are the ones I ordered.....
Old 10-15-2013, 06:11 PM   #43
Snailed
Snailed's Avatar
I have had good luck with Julianos also. I've probably installed six or seven sets from them. Good quality and good color selection. The retracters seem a lot easier to setup up than using OE ones from another application. Seems like the operating angle for the lock is a little wider than OE.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 10-15-2013, 11:53 PM   #44
familyfast64
familyfast64's Avatar
Originally Posted by Chevy Fleetside View Post
Usually when you buy a kit it comes with all the hardware. That includes big washers and stuff.
Nice interior, I bet your music sounds so good in there. Unlike sound waves bouncing off all metal surfaces. I want to make a clean, simple but hot rod head liner(more like a door panel is) and door panels to help fix this.
Live and let live
familyfast64 is offline   Reply With Quote
Old 10-15-2013, 11:58 PM   #45
familyfast64
Oh, and sry to change the subject. I too am interested in the adding of seat belts. I want to have the 4 point harness in the drive position, and at least two more lap belts. Lol it's funny cause both my girl and I fit fine with our two boys since they're not very old yet. These trucks are so wide. It's killer.
Live and let live
