Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 07-03-2009, 06:45 PM   #26
Mullet '72
Mullet '72's Avatar
Re: Rivet Removal: What Are Your Best Tools & Techniques?
Air Chisel and some patience...and some AIR GUITAR when it finally works
: NO, I will NOT take $200 for it
'72 C-20 Suburban
Mullet '72 is offline   Reply With Quote
Old 09-07-2010, 04:18 PM   #27
hotrod1
56 - autocross
hotrod1's Avatar
PLASMA!!!!!! Still not eazy, but way easier than the rest. Rivets suck unless u want them there.
hotrod1 is offline   Reply With Quote
Old 09-07-2010, 05:56 PM   #28
dwcsr
Hollister Road Co.
dwcsr's Avatar
The easiest way I have found to get them out is center punch the head, Drill 3/4 of the way through or at least past the second layer of steel with a 1/8 to 3/16 drill bit, Then follow with a bit that is about 3/4 the diameter of the rivet. drill to the end of the first drilling. Take a chisel and pop the head off then take a punch thats smaller than the drilled hole and drive out the rivet. This way you don't destroy the hole and bend any of the steel. They come out real easy.
I have tried the plasma cutter but it makes a mess and hardens the rivet making it almost impossible to drill if you have to.
dwcsr is offline   Reply With Quote
Old 10-30-2010, 12:19 AM   #29
planewhisperer
U.S. Army Green Beret Sniper
planewhisperer's Avatar
I use a center punch and drill them out. Works great and fast........
"YOU CAN RUN AND YOU CAN HIDE, BUT YOU WILL JUST DIE TIRED"
planewhisperer is offline   Reply With Quote
Old 11-23-2010, 05:07 PM   #30
ryans69chevy
Next summer I'am going to have to do this. Once I'am ready to put the stuff back on the frame are rivets the best to use? What size would I get and if rivets are the best way to go I'm sure I'll need a rivet gun. What brand is the best if that was the case? I don't have air.
ryans69chevy is offline   Reply With Quote
