Old 07-13-2009, 10:55 PM   #26
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: traditional hotrod
me too thanks for the info. But isn't the frame the same from 63-87 except for the frame horns on 63-66 are diffrent. And the body mounts are diffrent from the years. Just needing to be informed some more!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 07-13-2009, 11:02 PM   #27
PBFAB.COM
PBFAB.COM's Avatar
The 63-72 frame-rails are pretty close to the same. The main differences, as you have stated are the front horns, and the body mounts. However, the 73-87 frame-rails are not the same. The main difference being the frame-rail height (of course, body mounts as well).
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 07-13-2009, 11:05 PM   #28
PBFAB.COM
PBFAB.COM's Avatar
Wasn't channeling the body a pretty popular thing back in the 60's?
That might be another "old skool" option.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 07-13-2009, 11:08 PM   #29
N2TRUX
Happy to be here
N2TRUX's Avatar
The frames are similiar enough in the front suspension area that the crossmembers will bolt in. The 63-67 frames do not have the "flair" in it to accomodate a power steering gear box as power steering was not available. The exception being power "assist" steering.
The back half of the frame is where things are different. Let me see if I can remember the changes.
61-66 was trailing arm only, 67-72 was trailing arm "or" leaf spring which as mentioned, Chevy was standard coil optional leaf, and vice-versa on GMC.
Ok guys, how bad did I screw that up?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-14-2009, 04:19 PM   #30
ruffrida2005
thanks for the info guys!
Paul
Old 07-14-2009, 06:28 PM   #31
Iforgotmypassword
My 67 is coil, just thought they all were. Lots of interesting ideas to lower the truck. Channeling was something I considered, but I will already lose some headroom with the chop. I guess I will have to decide what makes the most sense.
My cab is off in the shop, and my frame is knee deep in poison ivy. Can someone tell me how much drop I need to get 6" clearance at the bottom of the rocker?Thanks.
Iforgotmypassword is offline   Reply With Quote
Old 07-14-2009, 09:24 PM   #32
Frizzle Fry
Frizzle Fry's Avatar
Originally Posted by XXL View Post
Leafs were standard, but coils could be bought optionally... just the opposite of Chevy. Not sure why other than market differentiation (??)
This is an old wives tale from what I can tell. I have heard it many times but never seen any proof of it. Neither GMC's nor Chevys list either as an option on the SPID. I have seen plenty of Chevys with leafs and GMCs with coils. I think it "sounds logical" so people just roll with it.
60-66 could be had with coil or leaf. See above for GMC/Chevy Coil/Leaf
Frizzle Fry is offline   Reply With Quote
Old 07-14-2009, 09:48 PM   #33
Shane
Shane's Avatar
I heard way-back-when that the difference in the coil on GMC / leaf on Chevy was not an option but actually dictated by where the truck was assembled.
Shane is offline   Reply With Quote
Old 07-14-2009, 10:17 PM   #34
joe231
joe231's Avatar
it will probably remain a secret unless we can find someone who worked for gm back when
CHEVY ONLY
Old 07-14-2009, 10:42 PM   #35
XXL
Seņor Member
XXL's Avatar
So neither are listed as options, yet we know both exist. The info I has suggests the following option for Chevy C10...
G50 Rear Leaf. Capacity 1750-lb each, 2 stage. $7.00 Mfr suggested delivered price.
And for the record, my wife did not tell me any of this.
XXL is offline   Reply With Quote
Old 07-14-2009, 10:46 PM   #36
N2TRUX
Happy to be here
N2TRUX's Avatar
Kinda of like the mystery of the under hood paint..black or body color...?
Articles-
"Refining Sierra"
Old 07-14-2009, 10:55 PM   #37
joe231
joe231's Avatar
CHEVY ONLY
Old 07-15-2009, 01:02 AM   #38
Frizzle Fry
Only old wives posses such knowledge Sounds like the G50 leafs were a higher capacity option??? and was G50 and option for GMC?
Old 07-15-2009, 12:20 PM   #39
ruffrida2005
Their is a guy on the board that worked for GM on our trucks in the engineer department. I'll try if I can find him. He works on the Volt now!
Paul
Old 07-15-2009, 01:12 PM   #40
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Could also drop the body mounts & body drop it
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 07-15-2009, 01:19 PM   #41
joe231
joe231's Avatar
using the newer frame?
dunno on a '67, but Strodder on the 60-66 side is putting a 64-65-66 cab on a 80-something cab, he had to cut and channel the floor of the cab to get it to sit low enough to use the factory located mounts.
CHEVY ONLY
Old 07-16-2009, 11:21 PM   #42
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
I meant with the 67 frame
There is no reason to go with the 78 frame
Sinister
Killer
Old 07-16-2009, 11:52 PM   #43
joe231
joe231's Avatar
ah, now it all makes sense
CHEVY ONLY
