#26 |
Gearhead and audio junkie
Re: Year One Crate Motor
#27 |
Junior Member
How much was the shipping to get that thing to Cali.?
63 C10 70 Coronet R/T 67 C10 70 Dart Swinger 71 K10 |
#28 |
Damn, I want this engine.
1971 Chevorlet Custom Deluxe C10 2007 Chevorlet HHR- lots of mods ![]() |
#29 |
shipping was around 150 or so. It showed up for a total of around 3100 or so, Engine is still running great, just went on its first real test drive, having some timing problems but i'll get it sorted out soon.
#30 |
Tonight when I go back to work on it, (finish some minor problems, full throttle hesitation, gotta perfect the timing) I'll take a better video of it without wind noise, and possibly one of it on the road.
PS. you should want this engine, its nice ![]() Last edited by mikajo39; 07-23-2009 at 12:06 PM. |
#31 |
Junior Member
I'm thinkin' 400+ lbs of tourque would make the Wife's '63 move right along.
#32 |
#33 |
sounds pretty crisp.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#34 |
Junior Member
Did you get your timing issue resolved?
#35 |
#36 |
Update : Well the truck has been home for its first week now. Engine is running very well, only problem is I haven't been able to resolve my timing issue. The Vacuum can collides with the intake manifold limiting my range of timing adjustment, so my timing is way retarded, I've gotten it to run by putting the vacuum advance on full manifold vacuum so it advances it a few degrees, allowing it to idle/part throttle good, but full throttle timing goes back to way to retarded, any one know where I could find a small (physically sized) vacuum can So I could clear my Intake manifold? I already tried one but it was bigger than the old one! Anyways video update time!
#37 |
Between Trucks...
What kind of distributor are you running?
Beat it to fit, Paint it to match... ![]() |
#38 |
Ah forget to say sorry, Its just GM performance parts HEI
#39 |
you might just have to get a non air gap style manifold. They don't really make too many sizes of vacuum canisters. I would get an edelbrock rpm or professional products if you're on a budget. Or you might try moving the order of the wires and twist it in a way to make up for that
'72 cheyenne super step, '05 long bed gmc |
#40 |
And please get a sport bumper
#41 |
#42 |
#43 |
I don't know why but I'm understanding what you're saying but I'm not. Guess the coffee hasn'y kicked in yet. basically pull it up rotate the cap or shaft put it back in and it should let me get into the right timing area? I was hoping I wouldn't have to pull the dizzy but oh well If I have too
#44 |
Yeah, if it's hitting the intake or the valve cover, you can pull the distributor up and move the rotor position one tooth. If the canister is too far to the right (hitting the intake) Pull the distributor out, and when you drop it back in, make the rotor face a little more to the left (like a tooth or so). Now you've kept everything the same, but moved the canister out of the way. You'll probably have to go down the distributor hole with a flat blade screwdriver and move the oil pump drive so the slot will line up.
If this doen't make sense, have someone help ![]() |
#45 |
Over summer school some girl took the bumper off her 90's grand cherokee on my original style bumper. It's curled at the ends being a stepside. And all it did was leave some little bits off that foam/rubber that's underneath plastic bumpers these days. She was hot, so I finished ripping it off for her, threw it in the back of her truck, and sent her on her way. Didn't hurt mine. If you don't want to take the distributer out of the engine, you can just move the spark plug wires by one spot and turn the distributor to make up for it...
#46 | |
#47 | |
#48 |
Mmmm, good ol slimey Guiness. Yup, just change em one over and turn it the same amount
#49 |
Looks like Ive got myself a small project for the day then woo! thanks man!
#50 |
So if the timing is too retarded I would move the wires over one in the counter clockwise direction correct? or would i go clock wise to get more advance?
