Old 07-09-2009, 10:15 AM   #26
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: can i take the AXLES outa a 72 and putem in my 68..
Originally Posted by oldblue1968chevy View Post
200 bucks is kidna high for a 5 lug 373 1 wheeler dontchall think....
No. You offer me a 5 lug 3.73 rear for 200 dollars and I will buy it on the spot any day of the week.
Old 07-09-2009, 10:30 AM   #27
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
huh....okay..your in a diff. part of the country..guess i may give the dude a ring then...its a good 20 bucks in gas away and trip in the ol blue truck.......but my goal for the summer was front discs and 5 lug everything..wanna get it done so i dont have to carry 2 spare tires to school next year lol...
John
1999 Toyota Tacoma 4x4
Old 07-09-2009, 10:40 AM   #28
Tx Firefighter
Let me give you a little advice I have learned over they years. It might save you a lot of money and aggravation.
The idea of swapping 5 lug axles into a 70 model rear can work sometimes. I have had several 70 model trucks and I can tell you from first hand experience that there are two different widths of 70 model rear ends. There is the early narrow type with the 6 lugs and there is a later wider type with 6 lugs. If you have the later wider type, you can swap the 5 lug axles into place. If yours is the early one, the axles will be 3/4 inch too long when you swap them in. Some of the members on here have also found this out too. It simply depends on what part of the 1970 year that the truck was manufactured. It was a running change.
Old 07-09-2009, 11:20 AM   #29
425HP409
425hp409
425HP409's Avatar
Wink Re: can i take the AXLES outa a 72 and putem in my 68..
Yes, you can take the axles out of a 72 and put in the 68 to change it to 5 lug. I know this because that is what I did. I installed ft discs from a 72 on my truck and then changed the rear axles so that I could have 5 lug all the way around. There is the problem that the axles are longer than the ones from the 68, but this can be overcome. The axles will still seal in the axle seal, however because they are longer, it puts the drum out from the backing plate and causes the shoes to not make full contact with the drum. This will cause poor braking and a soft pedal that can't be overcome by adjusting the brakes. You can overcome this by installing drums for a 11X2.75 inch brake shoe, whereas the original is an 11X2 inch shoe. This will give the brake shoes full contact with the drum surface, and a good brake pedal, with a little drum left over not used. To take full advantage of the 2.75 inch drum however, you can change the brake shoes, hold down hardware and the wheel cylinder so that you now have a true 11X2.75 inch rear brake system.
Here are the NAPA part numbers to do that:
NB 4401234 : 11X2.75 inch brake drum
UP 37048 : Wheel cylinder
UP 2237 : Complete hardware kit
UP 473R : Premium brake shoes (I only use premium shoes)
Here is the interchange data for the axles for 65-81 trucks
according to Hollander
67-69 12 bolt, 2wd and 4wd same part number
70 12 bolt, 2wd and 4wd same part number, depending if early or late
whether short or long axle
71-81 12 bolt, 2wd same part number
I hope this helps you guys,
Charles
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 07-09-2009, 11:27 AM   #30
Tx Firefighter
But if you do it that way, the axle bearing won't ride completely on the machined area of the axle. The machined area will be too far outward and the bearing will ride on about half the surface it is intended to.
Old 07-09-2009, 12:18 PM   #31
Skirkpat
Skirkpat's Avatar
And that's a bad thing...
1969 Short Stepside
1969 4 WD Suburban
1970 1 Ton Dually....Misfit
oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door
Skirkpat is offline   Reply With Quote
Old 07-09-2009, 01:29 PM   #32
Tycoon4u
Tooloose
Tycoon4u's Avatar
Originally Posted by Longhorn Man View Post
tycoon, was your rear ever swapped out for a 70 model year for better gearing maybe?
There is no way a 68 and a 5 lug should be the same. This has been documented on here and in the hollanders books as fact, that mid model year 70 was when the new wide rear end went in.
I have no idea, all I know is I took the 6 lug axles out and the 71 axles fit perfectly.
A legend in my own mind!!!
website: http://www.persmedequip.com/
'68 c10 (current project)
http://67-72chevytrucks.com/vboard/s...ht=cherry+bomb
'04 silverado (better halfs)
'07 wildcat 27rlwb(for sale) http://67-72chevytrucks.com/vboard/c...llinois&cat=17
Tycoon4u is offline   Reply With Quote
Old 07-09-2009, 01:36 PM   #33
Skirkpat
Skirkpat's Avatar
Stingray optioned maybe?
1969 Short Stepside
1969 4 WD Suburban
Old 07-09-2009, 02:03 PM   #34
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
Originally Posted by 72BlckButy View Post
Yep, and when you add drop spindles, it gets even wider!
Really?
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 07-09-2009, 08:26 PM   #35
Jim_PA
I ran the long axles in mine for 2 years with the wider rear drums. The bearings rode just fine on the machined surface.
Jim_PA is offline   Reply With Quote
Old 07-09-2009, 08:50 PM   #36
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
and I drove a 1980 monza for 6 months with only 2 lugnuts on the right rear wheel.
Never had a problem... but you can see the possibility for total disaster though, right?
Old 07-09-2009, 08:53 PM   #37
oldblue1968chevy
well my truckrearend is on the bakc burnier until my wheeler's rearend is done with....i gota stay outa the mud and water on that thing lol i had milked rearend and a loose ring/axle lol vewy vewy expensive fix lol dunno what im goin with yet..considerin that 373
John
Old 07-09-2009, 10:04 PM   #38
Jim_PA
I took the axles out, and the bearings rode right on the machined part of the shaft just farther from the hub than before. The most "dangerous" part about it is that the weight of the rear end of the truck is being applied to the axles 3/8" closer to the splines than before. I don't think I'd lose any sleep over that part either.
And yes, in the end, it really isn't the preferred way to do it, but IMO, it's safe, it works, and if you aren't ready to build or purchase another rear, you can go to 5 lug for however much you need to pay for the axles and brake drums.
Old 07-10-2009, 07:03 PM   #39
frankdatank01
On this topic of going to 5-lug with the narrow rear end, is there any mechanical/safety disadvantages to just having the 6-lug axles plugged and redrilled for 5-lug? Assuming something under 400HP?
frankdatank01 is offline   Reply With Quote
Old 07-10-2009, 07:06 PM   #40
frankdatank01
On this topic of going to 5-lug with the narrow rear end, is there any mechanical/safety disadvantages to just having the 6-lug axles plugged and redrilled to a 5-lug (5X5) configuration? MOSER has this listed for $60 or $80 dollars. Assuming something under 400HP. Just curious.
Old 07-11-2009, 05:52 AM   #41
Longhorn Man
nope, no problem. Get your hands on the 5 lug drums first, so you can take them in to the shop that'll be redrilling the axles. They'll also need to turn down the hub pilot hole.
Old 07-18-2009, 08:40 PM   #42
frankdatank01
Thanks Longhorn! Great advice!
