Old 07-17-2009, 09:37 PM   #26
Tagg33
Tagg33's Avatar
Re: Check it out
When you smoothed the firewall how did you deal with the horizontal seam that runs through it? I want my firewall to look just like yours. I'm pulling my engine tomorrow to start smoothing and start my Porterbuilt C4 dropmember install.
Ryan
84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s
My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328
Tagg33 is offline   Reply With Quote
Old 07-19-2009, 05:30 PM   #27
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
Originally Posted by tvblazer78 View Post
I like that, looks simple. How are you going to run your shocks?
The shocks will be run in front of the axle at angles / \ with these...
(these tabs will go on the bridge bar with shock bolts like the ones in the bottom picture)
(these are from *****************)
... but first I need to install the panhard bar. The whole pinion angle thing. I'll post some pictures of it as soon as I get that done
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!"
http://s657.photobucket.com/albums/u...view=slideshow
MI2CHEVYS is offline   Reply With Quote
Old 07-19-2009, 05:48 PM   #28
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
Thanks!
Well first I used a wire wheel to remove all the factory seam sealer (black sh*t), then I found some rust so I had to cut that out and patch in some pieces and grind the welds down. I also had to use a hammer and dolly to get the seam flat in some areas and tacked it down with a few welds and grind some more. Then fill the seam with all-metal body filler and sand smooth.
Good Luck its a pain in the ass, but its worth it in the end. ( that sounds funny)
Old 07-20-2009, 03:46 PM   #29
bagged74
its just $$$$$
bagged74's Avatar
Re: Check it out
Originally Posted by MI2CHEVYS View Post
yes in the front of the bar it has urethane replacment bushings, or i could use stock replacement. The rear of the bar has large heim joint, i wanted to be able to adjust it if needed. I still haven't installed the suicidedoors pan hard bar. I tested the system and it travels fine without any binding
maybe im missing something, but if you only have 2 link bars whats going to keep the pinion angle from rotating up when you apply torque to the wheels. Arent you going to need a wishbone or two more bars on the top? I know the panhard bar will keep it centered side to side, but i think you are going to need something else.
bagged74 is offline   Reply With Quote
Old 07-25-2009, 01:45 AM   #30
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
I've been moving to a new house so i haven't had time to respond, but i will be installing a wishbone. I just had to make the Blazer roll to get it up on a trailer.
Old 04-14-2010, 12:18 AM   #31
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
I've been busy redoing the rear supension and this is what i came up with. It travels fine without any bineding and the pinion angle doesn't change a bit.
Old 04-14-2010, 08:18 AM   #32
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Check it out
Man I like that, I want to use my stock hanger like that too. How long is that outer link to the hanger?
tvblazer78 is offline   Reply With Quote
Old 04-15-2010, 03:39 AM   #33
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
Thanks man, the lower bars are 24 1/4" from bar end to the center of the bolt hole for the hanger.
Old 04-15-2010, 05:51 PM   #34
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
here is a cool pic...
Old 04-16-2010, 12:37 PM   #35
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Check it out
I just saved that pic! And nice work!
Old 04-17-2010, 12:37 PM   #36
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
Thanks again I appreciate it.
Here is an update on the shocks. Now its time to take it all apart to weld it up permanent and paint it all (the frame and suspension).
Old 04-30-2010, 01:33 AM   #37
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
Well I finally welded up all the tabs on the axle tubes and made some braces for the rear of them to strengthen them. I even got to paint some parts.
Old 06-22-2010, 02:30 AM   #38
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
Well guys I was able to get some more things painted and put together.
I even got the motor in to mock up my headers. They fit very well.
I just need to do something about the air cleaner.
Old 06-22-2010, 01:39 PM   #39
justpball
justpball's Avatar
Re: Check it out
rear set up looks great, nice work!
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 06-23-2010, 10:51 AM   #40
Tagg33
Tagg33's Avatar
Re: Check it out
Nice progress!
Ryan
Old 07-04-2010, 08:57 AM   #41
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Check it out
Looks very good!
Old 07-04-2010, 08:59 AM   #42
BGRAFX
Re: Check it out
Looks good! What headers did you use?
BGRAFX is offline   Reply With Quote
Old 07-05-2010, 06:40 PM   #43
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Check it out
Also on your bar ends did you get 2.5 wide? and did you get your stuff from suicide doors? I have mine up in the air right now and getting ready to order something and I think what you did will work the best for mine.
Thank you sir..
Trav
Old 07-07-2010, 03:30 AM   #44
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
Let me go and measure for you... Yes 2.5". I used the leafspring for refrence. I bought all my steel at the local steel yard. The only things I got from them (S D) were the mounts for the bags and the panhard bar. I made all the other parts from scratch.
Your are welcome and Thank you, it means a lot to me that like my work.
Old 07-07-2010, 08:28 PM   #45
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Check it out
Thank you sir! And you have a sweet ride!
Old 07-07-2010, 09:40 PM   #46
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Check it out
Can you add some of the pics back to this thread, I would like to move this to the build part of the forums so more people can see it.
Thanks,
Trav
Old 07-08-2010, 01:35 AM   #47
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
Hedman Headers got them from Summit Part # HED-69648.
