08-12-2009, 12:12 PM | #26 | ||
Re: HELP! -- Brake Booster Install Question
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
08-12-2009, 01:08 PM | #27 |
Here is a pic of the detent hooked up using the Lokar oem style bracket and cable.
08-12-2009, 01:14 PM | #28 |
Here is a pic of your Holley Street Dominator intake manifold and it shows the same hole in that back intake runner that Rack Man showed. You can bolt a 90 degree nipple into that.
08-12-2009, 01:20 PM | #29 |
Here's the 90 degree I used from Spectre, part number 5946. It is 3/8inch NPT.
08-12-2009, 01:24 PM | #30 |
Or, if you have another small vacuum hose that needs to also be hooked up at that same spot, you can run an oem type intake fitting that looks like this one. It allows you to run a small vacuum hose to that spot and also run your brake booster. You can find them on Ebay for $20. Called an intake vacuum power brake fitting.
08-12-2009, 09:22 PM | #31 |
Awesome! Thanks for all the help & pics guys! This has been a great help. So I got out there and it looks like the PCV is hooked up to the intake so the vacuum on the carb is open. Is this the right spot? Looks like I just need the check valve and a hose the way I understand it now.
08-13-2009, 12:22 AM | #32 |
Stops like a Corvette guys thanks! Well more like a big steel truck, but you get the picture!
08-13-2009, 02:17 PM | #33 |
That's the correct nipple to use. Looks like the 12 volt ignition sourced power wire to the electric choke is missing. I see that the choke plate is open now, though.
