#26 |
McMullin
Re: 6 lug disc w/88 and up parts
70Suburban...thanks for the email. You did a great job on that write up. Why did you cut out a coil though?
Captainfab...Thanks for the tip on the rear end. Can you reweld the panhard bracket onto the newer rearend to get the correct angle or is it different altogether? How do I do the copy/past quote thing you guys did when responding? Thanks for the help! |
#27 | |
Rods
![]() Join Date: Nov 2002
Just keepin it simple. ![]() 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) Last edited by 70 Suburban; 11-05-2009 at 11:38 AM. |
#28 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yes you can weld the panhard bar bracket on the axle tube of the '69 rear end. I didn't know if you had the capability of doing that.
What I did in this post is just click on the 'Quote' box in the lower right of the post that I want to quote. If you want to quote more that one, click on 'MQuote' on the first one(s) and then 'Quote' on the last one Quote:
#29 |
so this is a bitt off topic , will the entiere front end off a 88-98 chevy 5 lug half ton swap over to a 66 c10 and also the rear axle i can get a good price (free) brake booster and power steering and all . and thank you in advance .
#30 |
No, the 88-98 front suspensions are not a bolt-in swap; 71-87 front suspensions are. Any rear housing will typically work provided you have the ability to weld the appropriate brackets on to the housing.
#31 |
so cross meber is out , what about control arms and spindels will they bolt to the 66 stuff . ? i can cut weld and drill most any thing .
#32 |
Again, no. The spindles can work w/the existing upper a-arms & 3/4 ton lower a-ar,s from a 6X-87 truck. That being said.... if you're capable of fabbing, anything can be done w/enough desire.
#33 |
Hollister, CA.
![]() Join Date: Sep 2006
When the time comes, I was also thinking of using the 88-98 stuff. Thinking there are more brake options with these years (??)
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
