10-09-2009, 07:07 PM | #26 | ||
Re: HOW do you remove spindles and control arms
Man pants is totally up to you.....safety glasses are a good idea though.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
10-09-2009, 07:12 PM | #27 |
67-72 parts collector,…
Removing the tie rod end from the spindle will also get you a little more "swing room" for the hammer.
10-09-2009, 07:13 PM | #28 |
Moderator
Don't hit the ball joint directly with a hammer. It will just mushroom, and make it even harder to remove.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
10-11-2009, 03:00 AM | #29 | |
'69 Chevy SWB
Keith, Longhair,
Thanks for the input I've tried all those methods and got no where. So I got an air hammer and pickle fork bit and I'm gonna give it a shot tomorrow. I'm just not that motivated to go out to the garage. That's all. But I'll let you know what happens. Thanks guys.
Matt '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
10-11-2009, 11:51 AM | #30 |
mini truck racer
Using the technique longhair and lolife are telling you they always just go pop . I use a 3# mallet .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
10-11-2009, 08:46 PM | #31 | |
'69 Chevy SWB
Well, I should be wearing a helmet and be in "special" classes. Why you ask. Well, it was dark when I was working on the 69 the other night, I hadn't unpacked my shop light, and was hitting the bump stop bracket. Not the spindle. One whack, POP, all done. Noe the driver side will be trickier since the springs were heated to lower the front. (PO) With the weight off the springs there is no tension on lower A-arm. So do I put the jack under the backing plate of the drum and do the same as the other side?
10-11-2009, 09:41 PM | #32 |
Matt,... you need "down pressure". A long pry bar putting pressure on the lower control arm should work,... while you hammer on the spindle.
Do the uppers first then the lowers.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-11-2009 at 09:41 PM. |
