Old 07-31-2009, 10:35 AM   #26
Piece of Work
Cultural Infidel
Piece of Work's Avatar
Re: trouble with eng starting need help
Does it turn over at all when it's hot? Or is it just dead until it cools down? My best guess, without any electrical testing is a bad starter solenoid. Very interested in what you find.
-Mark
posted via La-Z-Boy
-Mark
1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold
1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold!
It may be that your whole purpose in life is simply to serve as a warning to others.
A man is not complete until he is married -- then he is finished.
Piece of Work is offline   Reply With Quote
Old 08-01-2009, 01:48 AM   #27
billsbowtie
billsbowtie's Avatar
it turns fast when warm but want start . and when you hook the wire from battery to dis. it turns real slow. i got me a tester tonite . as soon as i get time i will start testing. bill
i have 67/72 chevy truck parts f/s.
billsbowtie is offline   Reply With Quote
Old 08-01-2009, 02:05 AM   #28
mclairmo
What turns fast the starter or the engine? If just the starter pinion is spinning but not engaging the felxplate/flywheel, then replace the starter. If the engine turns fast, then the starter and solenoid are fine. Must be ignition related or fuel. Is the coil ok? Test it. Same for the ignition module. Heat may make these items fail to work properly. What about your plug wires? Are they ok? Did you leave the old oem ballast resistor in the power wire to the HEI? HEI needs a full 12 volts, unlike points that want to see less volts. Electrical components hate heat. What about vapor lock? Are your fuel lines routed away from sources of heat?
mclairmo is offline   Reply With Quote
Old 08-08-2009, 01:15 PM   #29
billsbowtie
foud it there was some wires 1 from the starter 1 from the dis. and 1 from the harness on firewall harness that were naked and coroaded and touching fixed them now it starts and runs like a chevy should. thanks for all the help. bill
Old 08-08-2009, 01:16 PM   #30
billsbowtie
heres where they were. i also changed that fuel filter.
