Re: My 73 saga
Well, everyday i drive the truck it seems to perform a little worse rather than better.
Now I have exhausted my funds and I have a ****ty running truck. It's the same thing, I hit the gas and the 4 barrels are either not opening up or when they do the engine gets louder but doesn't go any faster. Also now we are back to the backfiring problem when I get on it. A friend of mine told me he thinks I have a vacum leak in the brakes somewhere as the brakes work, but not as well as they should. This is my first Chevy, I dont really know what is wrong or what to expect. All I know is my 07 Mazda Miata can outrun it on a strightaway....and that just don't seem right for a 454 NEW Motor I REALLY COULD USE SOME HELP, are there any new ideas considering the new info that this is yet another Carb and same exact problem. |
Re: My 73 saga
the filter is known to catch fire on a back fire.
so 1st things 1st... to check for vacuum leaks grab a can of carb cleaner(please be careful spraying around the dist. cap) and spray around the base of the carb and around and on any vacuum lines, and intake manifold while its idling. listen for a change in idle while spraying. it will either raise up and smooth out or start to stumble. thats where your leak is. next make sure your timing is set with a timing light. next hook a vacuum gauge to manifold vacuum. (the guages are cheap from any autoparts store) your looking for between 18-22psi w/ a steady needle. when you crack the throttle it should drop 2psi and jump to around 25psi. that is a good running engine. a low steady reading (8-14) is usually valve timing. (13-16) is usually ingition timing is off. needle floats between 12 and 16 adjust the idle screws. there is a ton you can learn from a vacuum gauge. more than i have listed from burnt valves to spark plug gap to close. its helped me diagnose problems fast and easy. and its a great tool for someone just learning. note: these are the 1st things i do when something doesnt seem right...(with a new motor the obvious things like new plugs and wires should already be addressed) its usually trial and error and i have to go back and forth between the timing and carb adjustments. btw, what carb are you running? and are you sure the tranny isnt slipping? i'm sure others will chime in and help with more suggestions and if anything isnt right in what ive posted... good luck man! Dennis
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list
Re: My 73 saga
Thanks Dennis, thats a lot of good info....I will go get a gauge tomorrow.
I dont think the tranny is slipping, just had it gone over....all seals and filter, new fluid etc and everything seemed to operate well and function as designed I am running a Edelbrock Performer 750cfm carb, it's new as well as the intake manifold and carb plate and fuel lines as wellas fuel pump plugs wires coil cap points etc. |
Re: My 73 saga
ok, got the truck running great!
had to take it back to have the manifold gasket replaced and the exhaust tube packing replaced at the manifold. so I bought some Sylvania Silverstar headlights and now I have another problem, it seems that the conventional headlights have longer posts on them than the Silverstars so now the headlights go on and off when I hit bumps. Anyone else have this problem? and what did you do to fix it? I noticed that the plugs have a shroud that curve to flush with the back of the bulbs I was thinking of taking a Dremel tool and cutting some of that off to be able to push the plug onto the posts more. My next project is a set of HD Bilsteing shocks, and reshaping the springs along with adding an extra leaf. And a brake proportioning valve that needs to be replaced. I am also looking for the trim clips that attach the trim to the body, andone know where I can get them? they are disco'd through GM. Thanks for the help! ![]() Happy Thanksgiving!! |
Gettin It One Pice At A Time
Re: My 73 saga
I had the same problem. I replaced the light plugs in's with new ones. snug as a bug in a rug! cost was about 5 bucks for the plugs and maybe 2 bucks in heat shrink tubing!
RIP ELJAY ![]() Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby |
Re: My 73 saga
Does anyone know where to find the molding or trim clips for these trucks?
My aluminum body trim is in bad need of some new clips but I can't seem to find them anywhere. Many Thanks! |
Re: My 73 saga
just so people know I found these clips from LMC, i guess you guys didnt know they sell the molding clips. but now the next guy who asks can search and find this I hope.
Re: My 73 saga
Well I have come to a point (after I got everything fixed...lol) that i am going to sell my beloved truck....I will be turning 43 in October and have always wanted a Harley so i am going to try and sell it to fund the bike purchase while I can still ride
![]() I am off to see how much it costs here to place an ad in classifieds |
Re: My 73 saga
Sorry your making that decision, but I understand you gotta do what you gotta do.
Hopefully you are patient, 'cause even though you have dumped a lot of coin into this project, it doesn't necessarily mean that someone else will want to. I've usually never paid more than half of what someone had put into their vehicle. |
Re: My 73 saga
yeah i know, i have a price in mind...maybe I'll get it maybe not but hope I can get close...somebody's gonna get a helluva deal tho
![]() since I have done most of the work alreadt...lol |
| Bookmarks |
