Old 07-28-2009, 10:07 AM   #26
tires2burn
tires2burn's Avatar
Re: Why does my motor sit back so far?
It looks like your engine mounts are bolted to the rear frame mount holes. You should be able to move it foward about 2 or 3 inches into the foward holes. The trans cross member will have to be moved also. And then comes the drive shaft.
tires2burn is offline   Reply With Quote
Old 07-28-2009, 11:43 AM   #27
jamieg
Originally Posted by 71swb4x4 View Post
That is the stock motor placement for the 4x4.
Nice little tidbit of info, you may have just saved me some work.
jamieg is offline   Reply With Quote
Old 07-29-2009, 12:09 PM   #28
andy applegate
if you have a stock 400 crank, it would be externally balanced and would require a harmonic dampner and flex plate for a 400 crank. they have balancing weights affixed to them. you could check these two visually. on the other hand, you would not want a 400 flexplate or dampner on a 350 crank.
andy applegate is offline   Reply With Quote
Old 07-29-2009, 12:14 PM   #29
ll____b0t____ll
ll____b0t____ll's Avatar
Ok Im confussed is it a 350 or a 383?
If its 383 than thats a 350 block and 400 crank right? as a 400 block and 350 crank would be a 373......aahh 373 I really miss that moter vroooooooooom!
ll____b0t____ll is offline   Reply With Quote
Old 07-29-2009, 04:26 PM   #30
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
400 block, 350 crank equals a 377.
Old 07-29-2009, 07:30 PM   #31
ll____b0t____ll
Good catch I must have rear end gears on the brain as thats what im working on now lol.
