Old 01-05-2010, 11:07 PM   #26
msgross
msgross's Avatar
Re: 1972 power steering gear box on a 67 with no dimple in the frame
i've mocked it up and don't see any issue.. there are others with a similar setup that might be cheaper...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-05-2010, 11:09 PM   #27
msgross
msgross's Avatar
here is one from a board vendor..
http://67-72chevytrucks.com/vboard/s...d.php?t=332923
The Garage:
Old 01-05-2010, 11:27 PM   #28
Wildstreak
"something witty here"
Wildstreak's Avatar
I think captainfab(vendor on the site) has a bracket as well, that looks very nice.
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 01-13-2010, 03:04 PM   #29
rcrahn
rcrahn's Avatar
Originally Posted by jbristo67 View Post
Some one wanted to see the other day that a power steering gear box would fit a 67 without shimming the box out or dimpling the frame. Here is mine
Looks good and thanks for posting it.
I have a 67 C20 originally with manual steering that I want to convert. The 72 PS box you used, what vehicle was it out of? Do you happen to know the PN on the box? What is the ratio? Did you use your orginal pitman arm or another one?
Sorry for all the questions. Just trying to get it right the 1st time when I do it.
rcrahn is offline   Reply With Quote
Old 02-13-2014, 08:36 PM   #30
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
So the first year of power steering on C10's was 68 if I read this right. Does that apply to C20 and C30's?
Here is what I have. Going by the ID on he rail it's a 68. It's a dually so I would assume its a C30 altho I believe C20 and C30 have the same frame. The cab was a C20 vin but it didn't match the frame serial number.
Alan's Classic is offline   Reply With Quote
Old 05-19-2014, 11:13 AM   #31
Jkobernusz
I just put in a power steering sector on my 67 chevy with raised bosses and still had to use two 3/8 washers that I cut to make them C's so the bump on the sector didn't hit the frame. Just wanted to put that out there.
Jkobernusz is offline   Reply With Quote
