07-31-2009, 09:06 AM | #26 |
Re: Cutting holes in a perfectly good hood
Great vision and well executed!!
07-31-2009, 09:26 AM | #27 |
Between Trucks...
That's b!tchin.
Beat it to fit, Paint it to match... |
07-31-2009, 10:25 AM | #28 |
Never Ending Projects
I have to say the work is top notch!
My question would be why all the work to basically have a 2 bbl carb? All that work, I would want all three carbs to work otherwise it's just all show and no go. Again, great job on the work, props for that.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-31-2009, 11:01 AM | #29 |
motor exploder
makes me think what it would've been like had Mad Max driven a 67-72 C10!!!
that is maniacal!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
07-31-2009, 11:17 AM | #30 | |
Señor Member
Thanks, all, for the positive comments!
I have an "all go" car too, so this one is fine for getting me down the road at 65. Quote:
Yes. He cut it in 2 pieces so we could use thinner (read as "cheaper") stock, and then they're bolted together. As you can see in the CAD 3D, the original plan was to add the necessary height on the carb side. Again, due to material cost, we were going to cut those as separate pieces. However, after lots of measuring, it turned out to be better to add the bulk of the height on the bottom of the unit. However, mekdad had already finished cutting... so we used an off-the-shelf 4bbl spacer. If I was being anal, I'd probably have mekdad recut the bottom piece again with the added spacer height built in. BTW, one of the things that didn't get done, that I hope to get around to fairly soon... I want to bead blast the whole manifold to give it a cast look to match the Clifford on the bottom. Right now it's a little too "machiney." I've still got to make a mount for the fuel distribution block, and tidy up a few other things as well.
07-31-2009, 11:32 AM | #31 |
67cheby
First let me give you props when i seen the post i almost didnt look(i just assumed someone was hackin a hole in their hood) but than my curiosity got the best of me ...Anyway it looks sweet, great job... My question is on the hood hinges where did you get them , they look super nice .. Thanks Mike
07-31-2009, 11:46 AM | #33 |
PITbut
My initial thoughts were WTF are you thinking... And the final thought was your freakin awesome...
More pics please.... Just no tutu's this time.
New project. 1971 Twin Turbo blazer http://67-72chevytrucks.com/vboard/s...d.php?t=676047 My new YOUTUBE channel.. Videos of my truck and a current walk around. Lyrikz74 Youtube channel DONE! SOLD! My 1971 stepside build thread My Build Thread UPDATED 6/11. DONE and sold. |
07-31-2009, 11:47 AM | #34 | |
chevelito
poser! j/k...this rig rocks!
New deadline...when my son can drive. Aloha from Honolulu, HI |
07-31-2009, 11:58 AM | #35 |
I'm not a fan of any holes in the hood, but this is unique and well executed. Best job I've seen. If the carbs all worked, then you would be getting the best engineering award, too.
07-31-2009, 12:06 PM | #36 |
67cheby
i can click on the link you sent but there is no brand or ordering information ie company name??? thanks mike
07-31-2009, 01:40 PM | #37 |
On the college boy budget...
Dude, that is coolest thing I've ever seen. When I first saw the title of the thread I thought, "Ah hell, this is gonna be something akin to 1980s prostreet graphics and paint." Obviously I was pleasantly surprised.
Way to go.
-'68 C10 short/step- 350/350 |
07-31-2009, 02:19 PM | #38 | |
07-31-2009, 03:14 PM | #39 |
67cheby
thanks for your help, anything special i need to know about mounting or using these, or was it a pretty easy conversion??
07-31-2009, 03:46 PM | #40 |
BlahBlahBlah
Nicely done...dig the chop, now I dig the hood.
07-31-2009, 04:21 PM | #41 |
I am a Referee of life.
Great execution of an off the beaten path mod.3 dueces would be an awesome set-up but hardly worth the hassle since a 6 is still going to be limited on performance.The look is great though and you made it work without tuning problems.And you are going to get some stares from folks when the hood is closed since they will wonder why the carbs are on the left side only.
You also found some members with awesome skills to execute a plan.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
07-31-2009, 05:36 PM | #42 |
That was my thought also, but then I was pleasantly surprised, good work.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
07-31-2009, 05:37 PM | #43 |
Fat Fendered Fleetside
incredible!!!!
what a creative idea, and very well executed!! Thumbs up~~
71 GMC lwb 56 Big window swb 93 GMC Sonoma (dd) radiused fiberglass fender project for 67-72 |
07-31-2009, 05:42 PM | #44 |
Looks good!
07-31-2009, 08:02 PM | #45 | |
This was one of my concerns as well but like XXL said with the PB DM in their the motor is very rigid with out being solid. I pulled it out last night and gave it the power brake test and their we no contact problems at all. I must say some of the things XXL has asked me to do has had me wondering what he's been smoking. But in the end every mod has worked very well with everything else on the truck. My first thoughts were "you want me to do what to your hood!!" and if I remember right I even tried to talk him out of it. I am glad he is more stubborn than I am Wait until he shows all the rest of the mods from this round of metal surgery. Kevin LFD Inc. |
07-31-2009, 11:00 PM | #46 |
Señor Member
Here are a couple of shots that give you a better view of the effect (along with a gratuitous shot of Kevin's "rokcrln" truck).
Note also the front rolled pan and welded seams. I decided I didn't want to build another bumper after the previous one was damaged by movers (see especially post #62 where I give them a public referral as requested. If you're interested in their services, please feel free to call them on their toll-free number). While the bumper was very "smooth," the rolled pan really pulls together the super-shaved theme of the truck well.
07-31-2009, 11:32 PM | #47 |
PROJECT 7DEUCE
Ken I know for one I am glad to see you getting treated right with the work being done to your truck.. Its always been one of my favorites on the board even when it was in paint jail 9 million times... I am glad that you chose kevin to do the work as it is outstanding and I am sure it will be *****IN when done not like it aint already...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-06-2009, 04:03 PM | #48 |
*****EN is right!!!! that looks so clean.
08-06-2009, 07:51 PM | #49 |
Bad ass and original! Shame we don't see more sixes
08-06-2009, 11:25 PM | #50 |
Very nice
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
