Old 09-20-2009, 02:47 PM   #26
djracer
djracer's Avatar
Re: Project No-buck!
keep up the good work.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-28-2009, 07:52 AM   #27
VA72C10
VA72C10
VA72C10's Avatar
Nice progress, you're blowing right through this build.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 09-28-2009, 10:22 AM   #28
Ackattack
Ackattack's Avatar
I got a little more work done this week. I got all of the wood cut to the proper size, all of the metal strips cut to size and holes drilled.
I started installing the wood. I added an additional support. Basically it appeared that there is not a support between the wheel wells, so I added one. It makes the floor deflect A LOT LESS.
I started bolting everything down, but it's kinda difficult to do by yourself So I need to finish bolting the strips down, then drill the holes for the bolts that actually bolt the bed to the truck.
I also got the brakes all squared away after my failed attempt at adding power brakes. Basically the power MC was leaking, so I just put the manual MC back in. I had to get 2 new short brake lines since I kinda bent up the old ones in the process of trying to install power brakes.
Oh, I got a replacement battery for FREE Returned the one it came with to wally world, cause it was bad.
Then I installed a different sending unit. The original one was leaking. The tube that actually goes through the metal "disk" that you can see was seperated and was leaking real bad. Luckily I had an extra one.
After that I added a middle set of seat belts, and replaced half of the drivers seat belt....should be safer now.
Finally I put the bench seat back in.
No pics I'll get some when I finish up the bed floor.
Ackattack is offline   Reply With Quote
Old 09-28-2009, 10:49 AM   #29
my67chevytruck
Under Construction
my67chevytruck's Avatar
great progress.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 10-04-2009, 03:59 PM   #30
Ackattack
Ackattack's Avatar
Got the bed floor all together:
And then I threw on some sheet metal. "new" door and fender are courtesy of Livrat, Thanks A LOT!
I have some additional bolts to put in for the sheet metal, install the cowl, and a few other little things. Then I also need to finish up welding the inside of the bed.
Old 10-04-2009, 11:33 PM   #31
nuke1
nuke1's Avatar
Hey, now that thing is really starting to come together and look like some thing, great job so far.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-07-2009, 12:41 PM   #32
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You said this is project "no buck" and that your heater levers are broken. I'm a no buck kind of guy so here's what I do in that situation. Flat strap steel and some work...
Cut to shape and drill the pivot pin hole...
The center one is the hard one since it has the trough for the switch arm. You have to weld a bit and grind it out. Still, no big deal...
Use a tiny bolt and jam nut to act as the cable pin.
Use countersunk screws and nuts to replace any of the broken faceplate brads.
They will last forever if you build them this way.
Old 10-08-2009, 11:20 AM   #33
Ackattack
Ackattack's Avatar
Or get a broken used one from Livrat for free and combine the two to make one working unit
Thanks for the idea though.
Old 02-23-2010, 05:23 AM   #34
71'tahoe
71'tahoe's Avatar
Did yu sale this truck or is there any new progress?
71'tahoe is offline   Reply With Quote
Old 06-01-2010, 01:17 AM   #35
Ackattack
Ackattack's Avatar
CHAPTER 2:
No buck is still around. I've had it for sale for awhile, been using it to for dump runs, and home depot runs. I had 40 cases of slate tile in it, as well as 50 sheets of drywall in it (2700lbs of drywall). So it's been nice having a 3/4 ton.
While driving it around, it started sputtering and running poorly. I initially thought it was the ignition. I rebuilt the distributor (new pickup coil, rotor, cap, coil) still ran poorly. Replaced the fuel filter, with a see through filter. It wasn't filling up when running, so I replace the fuel pump. That helped a little, but it was still running poorly. Finally I rebuilt the carb, and now its running great.
My idea right now is to go back to the salvage yard and get a 68 chevy front clip/bumper and paint it flat black, possibly convert to 5 lug 1/2 ton running gear, and drop it down a few inches. I was thinking of talking to the salvage yard about putting their logo/phone number on the doors as a "shop truck" in exchange for the parts....so we'll see how that goes. Kinda think that would be cool, but they probably won't go for it, but it doesn't hurt to ask.
I know you all love pictures as much as me, but I didn't have time to get any after I got it power washed. I'll get some up soon.
Old 06-02-2010, 01:23 AM   #36
Ackattack
Ackattack's Avatar
I guess that's why they invented plasma cutters
Old 06-03-2010, 12:11 PM   #37
Ackattack
Ackattack's Avatar
The drivers side rocker, a small portion of the floor, small portion of kick panel, and front cab support will get replaced.
On the passenger side, it looks like all that will need to be replaced is the front cab support.
Old 06-13-2010, 09:30 AM   #38
hgs_notes
GEARHEAD
hgs_notes's Avatar
I like the build. Instead of swapping to 5 lug though, maybe check out the available 8 lug wheels. With the popularity of the new big diesels there are a lot to choose from. Keeps your cost down and you still get the hauling capabilities of the 3/4 ton.
hgs_notes is offline   Reply With Quote
Old 06-13-2010, 10:45 AM   #39
mcbassin
Still Learning
mcbassin's Avatar
Looks like a great score finding the cab. I'm actually glad you didn't sell it, so we can watch you through this builde too.
mcbassin is offline   Reply With Quote
Old 06-16-2010, 10:51 AM   #40
Ackattack
Ackattack's Avatar
Another update,
I went to the salvage yard last weekend to see what parts I wanted, see how much they cost, and see if they'd give them to me if I put their logo on my door.
No go on the sponsorship
So I found most of the parts I wanted except for a coil spring 5 lug axle. They also wanted $300 for a 73+ front suspension. I didn't get anything while I was there due to lack of time, but I'll be back for some parts.
After them telling me price of the suspension, I started scouring craigslist for a 71 or 71 1/2 ton. I ended up getting a 72 suburban for the suspension.
It doesn't have an engine it it, so I think the front will set pretty low, and the rear is as you see.
It will be a few weeks until I start swapping suspension parts.
I pulled the windsheild, cleaned out the drip rails, and started repairing the minor rust holes around the windshiled frame. I hope to have the repairs done in a few days, my new windshield gasket here, and all prepped (seam sealer, drip rail filled, etc) so I can have the new windshield installed ASAP.
While I have the windshield out, I'll start painting the cab so I don't have a tape line or paint on the gasekt.
Old 09-09-2010, 01:19 AM   #41
Ackattack
Ackattack's Avatar
Another update
No pictures yet, but I did get the front suspension pulled out of the old suburban, power washed, oven cleaner treated, and then power washed again. I'll hit it with some rattle can black before it goes in.
I also got a 67-68 hood, 67-68 chevy grill, chevy tailgate, and a 68 right fender from the salvage yard. I've been working away on straightening and painting them. My left side fender is a 67, so I got some filler plates to fill in the side markers too. I should have paint on the hood and grill by this weekend. The fender is a few days away.
I popped out the windshield and cleaned out the seam sealer and drip rail sealer, re-applied, painted and then had the windsheild put back in. So hopefully it will be awhile before any water starts getting back in again.
So I decided to paint the grill inserts off white to give it a little more contrast with the red. I'll also paint the "CHEVROLET" on the tail gate with the same color.
So maybe next weekend, I'll pull the truck into the garage, pull off the current front clip, pull the engine, and pull the front suspension. Swap in the 1/2 ton suspension. I'll go ahead and clean up the front frame rails while I'm in there too.
While I have the engine out I'm going to swap out intake manifold gaskets and oil pan gaskets just to stop leaks. Might also see about the rear main seal while I got it out. Then I'll clean up the engine and give it a fresh coat of paint. While I have it off, I may just replace the stock intake manifold with an aluminum one.
I also thought of a door logo. Since I can't really think of a shop name to put on it, I'm gonna paint a bullseye on the door with "your logo here". Thought this would be kinda fun.
Old 09-09-2010, 10:23 AM   #42
madmopar
This guy has got to be stopped
madmopar's Avatar
I got no love for the burbs, but thing looked too nice to part out... How much did you have to give for it? Sad to see those 8 lugs go, but the 5 lugs give you more options and resale value... Looks good... keep us posted!
J P Evers
1970 4x4 LWB project: http://67-72chevytrucks.com/vboard/s...d.php?t=415134
madmopar is offline   Reply With Quote
Old 09-09-2010, 11:14 AM   #43
Ackattack
Ackattack's Avatar
$800 for the burb, the outer sheet metal is rusted out from about the trim down.
Old 09-09-2010, 11:18 AM   #44
mcbassin
Still Learning
mcbassin's Avatar
We are definetly going to need some pictures of all that progress. Cool score on the burb! It will be going to good use.
Old 09-09-2010, 12:20 PM   #45
threeonthetree
threeonthetree's Avatar
isnt that one of those rare three door suburbans i wouldnt part that old girl out... hahahah
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 09-09-2010, 06:00 PM   #46
Looking forward to the pictures. Love watching your builds.
Old 09-09-2010, 06:21 PM   #47
Trailrider95
Trailrider95's Avatar
Great build thread so far, and we're in the same lil city! that's pretty wild.. lookin forward to seein this truck on the road.
Trailrider95 is offline   Reply With Quote
Old 10-21-2010, 12:15 PM   #48
Ackattack
Ackattack's Avatar
The conversion has started.
I pulled then front sheet metal and the engine. Then I removed the 3/4 ton front suspension and got the 1/2 ton front suspension bolted in place (just a few bolts to hold it in place for now.
I tore down the engine to clean it up. It was a leaky, greasy pig of a motor and I was expecting the worse when I pulled it appart. To my delight the cylinder walls and pistons look great. There is no ridge a carbon build up at the top of the cylinders, so it seems as though it was recently rebuilt. However, whoever assembled it wasn't too good with gaskets. There is RTV everywhere, and obviosly lots of leaks. I cleaned up the block and intake manifold last night. I'll drop the oil pan to due further inspections. I bought a gasket kit and will be replacing the rear main seal and oil pan gasket (one piece pan gasket) and the rest of the gaskets and give it a nice clean looking paint job.
The I pulled out the rear end / suspension. The bolts holding on the leaf springs were a real booger. I ended up cutting the rear bolts and removing the rivets that hold the front hanger to the frame to get the rear out.
I also got the 1/2 ton rearend out of the suburban and got it power washed. I removed the trailing arm hangers, panhard bar hanger, and the coil spring reinforcing plates. I love rivets!!!!
I would have started bolting the 1/2 ton rearend into place, but I need some bolts to do it. Stopping by the bolt store on my way home tonight.
The 1/2 ton front suspension has "Western" drop spindles on it and the rear springs are marked 4HD, which I take it to be a heavy duty 4" drop spring. So the truck should have a nice stance when I get it put together.
Old 11-03-2010, 02:58 AM   #49
Ackattack
Ackattack's Avatar
Finally: an update with pictures!
I got the engine all cleaned up and put back together....they look so pretty on an engine stand!
Then my awesome wife helped me stab it in.
Notice the 5 lugs
Here is the christmas color theme for now
Here is the grill that is ready to go on
And here is the hood and fender that are ready to go on.
I have a few things to do before the front sheet metal goes on. Hook up all of the engine and finish bolting it in mainly.
Then I will pull the bed off to paint the back of the cab as well as put in the coil spring suspension crossmember that the shocks mount too and the the spring reinforcement plates. Luckily it seems that the drive shaft that was used with the dana 60 should work with the 12 bolt. I had to get a conversion ujoint. Initially I thought the rearend used a 1310 u-joint, but it turns out that it uses a 1330 ujoint as I am now assuming this originally came from the same vehicle that the front suspension came from (73+). So I have to install that and a parking brake cable. Then finally I'll hook up the rear brake hose.
Old 11-03-2010, 07:11 PM   #50
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
dude you are awesome! How do you get so much done!
John
1999 Toyota Tacoma 4x4
