11-15-2009, 06:53 PM | #26 |
Re: Replacing the clutch on a 1960 GMC, SM-318
Also found a shop here in town that shortens driveshafts for a really reasonable $65, and around $125 I think for aluminum (no warranty on aluminum mods on used shafts). They'll custom build a new driveshaft for you for $250 in steel and $400-$500 range for aluminum. Columbus Joint and Clutch. Then I just need to get the dial indicator to measure if I have any runout from my crank centerline to the bellhousing register for the transmission input bearing retainer, fab up a rear trans crossmember, and then get a speedometer adapter for the Tremec from the ford style to GM cable.
Chuck in Ohio *1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end *1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project *Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc Last edited by Chuck78; 11-15-2009 at 06:55 PM. |
11-15-2009, 07:30 PM | #27 |
Got you on the stability. Great that you found those other resources.
09-24-2016, 10:00 PM | #28 |
Hey guys I'm helping a friend with his clutch on the same rare 305 v6 and we got the same wrong parts. Can you guys tell me what you ended up using. I cant find anything that works. Thanks.
09-25-2016, 07:45 AM | #29 |
If you search 6066GMCclub.com, you'll find that the AMS Rhinopac 04-528 is the one to use. Don't use the Perfection brand that fits most of the same applications, as it will not fit the gmc. Use this brand only. Or just get the original clutch and pressure plate remanufactured. Hite Parts Exchange did an excellent job remanufacturing mine.
Chuck in Ohio *1962 GMC 1000 Panel Truck - 305D/Saginaw 4sp soon: 351C V6 + AX15 5sp OD trans, & 75-87/91 disc brake front end *1988 Suzuki Samurai 4x4 project, VW 1.9L mTDI, Toyota R151F transmission & Toyota full floater axles, LWB body tub stretch project *Many 1977-1979 Suzuki GS motorcycles, Kawasaki KDX220R, '77 Suzuki PE250, etc |
09-25-2016, 11:13 AM | #30 |
Just did this folks. The AMS Clutch kit has the Same issue the rest do. But the nub on the flywheel side is not quite as tall. You will find that machining it down provides better results. Ask me how I know. Everything else is perfect except the disc. Also be aware that the clutch fork and throw out bearing have to also be in while you install the trans. Unless you have someway of collapsing the fingers. Due to the stupid small bell housing design Nothing is somewhat easy to install. But when done the results are nice.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
09-25-2016, 09:06 PM | #31 |
Thanks guys. Unfortunately the shop that rebuilt the engine tossed out all the clutch parts and gave us new parts that dont fit. Now we're blindly trying different parts to see what works.
09-25-2016, 09:39 PM | #32 | |
it is the chevy bellhousing mounts that you can use ron |
09-25-2016, 11:46 PM | #33 |
You can get an AMS disc and then machine the nub down and it should work. Though I would recommend the whole kit so you have everything from one place. If I hadn't thrown my old disc away you could have had it for a rebuilable core, but I really don't know if it was rebuildable! haha It was pretty toasty.
09-25-2016, 11:56 PM | #34 | |
ron |
09-26-2016, 12:45 AM | #35 |
Guaranteeing is a dangerous thing. Worked for me...Should work for him. But I will not be the one to say it Will work for him.
09-26-2016, 07:30 PM | #36 | |
ron |
09-26-2016, 09:57 PM | #37 |
Thanks for all the help guys. We ordered the kit already. Hopefully we get done with this and sit the motor in soon.
06-01-2020, 08:56 PM | #38 |
1960 GMC Burb
Going through the same with my 60 GMC .. This was really helpful.... I am waiting for a disc part number from a shop that actually solved this for a client a year or so ago... If I get it I will post it...
1960 GMC Suburban 1/2 ton V-6 2nd generation original owner 60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban 60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs 2003 Tahoe LT |
09-01-2020, 08:33 PM | #39 |
Just here to tinker
Glad this thread is still alive and helping people out!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
09-14-2022, 09:18 PM | #40 |
I'll be doing my clutch disc this weekend.. Glad I found this thread..
