08-23-2009, 12:48 AM | #26 |
60-66 Nut
Re: 63 C 10 it begins
WMS to WMS (wheel mounting surface) is the correct way to measure the width of a differential. That's the same as drum face to drum face
So I said 63.5, you say 63.625.....that's only .125 difference between us.....close enough. The 58.5 sounds more like the housing width/length.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-23-2009 at 12:49 AM. |
08-23-2009, 09:43 AM | #27 |
"Where were you in '62?"
What size tires and rims you putt'in on your truck?
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
08-23-2009, 10:13 AM | #28 |
Captainfab I am sure the extra 1/8" is probably the rust build up, the 58.5 was axle tube flange to axle tube flange. The numbers did check out on it being a 72.
1bad62pro/street Not completely decided on the size although I have decided on the style. I plan on running the American racing Salt flat style thinking somewhere in the area of a 17x8 in the rear and a 16x7 in the front. Looks like I will need to increase the backspace at least a inch a side due to the wider front and rear. So much to do prior to getting to wheels have not sorted it all out yet. |
08-24-2009, 12:19 AM | #29 |
60-66 Nut
I think those wheels will look awesome on your truck. You don't see them on trucks often, especially this vintage.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-24-2009 at 12:19 AM. |
08-24-2009, 09:04 AM | #30 |
They are reasonably priced and allow for custom offsets and studs besides I could not afford real Halibrands.
