#26 |
Re: Who's got them 454??
These trucks did come with big blocks in them so if your going to order or buy a shroud,,, Just use 396 or 402 as an engine ,,,they have the same outside dimensions as a 454. You will need to know what other stuff you have though,,,ie, long/short water pump early or late mounting set up(looks like the right one for the truck) what fan you have and if your going to need spacers or not, if your engine is mounted in the forward or rear mounting position?
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub Last edited by sick69; 08-17-2009 at 10:00 PM. |
#27 | |
Sorry for the stupid questions but it was somebody else who installed this engine so i don't know. |
#28 |
I'll try to get pics of the two mounting positions tonight. My front wrap is off so it should be easy.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
#29 |
its all about the +6 inches
your fan is close enough that you won't find a shroud that'll fit, and in reality, its close enough it won't do a whole lot.
If you want it bad enough, it'll have to be custom made. |
#30 | |
and has anyone used electric? |
#31 |
#32 |
my 2 cents. i dont drive a chevy yet, how ever i do drive a big block Intl truck. i will only run clutch driven better cooling and i have nver overheated even with holes in my radiator!
#33 |
![]() Join Date: Jul 2009
What I would do is do what I did on my race truck, I bought a shroud from here,
http://cmwraceparts.com/grp6B.php Just trim it to fit, you may need to cut a lot off to get it to fit or you could also go with an electric fan. Some of the electric ones have a shroud built in. Last edited by mikey531; 08-18-2009 at 04:59 AM. |
#34 |
"THE GREEN GOBLIN"
I am using Stock Dual Cooling Fans from LT1 Firebird Trans Am/Camaro PO had them installed when I bought the truck it cooled fine when I would drive it and he didn't seem to have any problems with it. you can get them on Ebay all day long real cheap..........
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
#35 | |
and i have only 3 inches of clearance between the WP and RAD. |
#36 |
With only 3 inches of clearance, very little is going to fit in there.
#37 |
![]() Join Date: Aug 2005
this should do the trick. Mine will be here this week. http://www.summitracing.com/parts/FLX-410/
#38 | |
#39 | |
![]() Last edited by chirt; 08-18-2009 at 06:34 PM. |
#40 |
#41 |
#42 |
#43 |
just curious, does any one know how many cfm a stock fan and shroud pull? Is it more the two duals pulling the 2500? The variable speed control running till cool down has to help vs a stock fan stopping when you kill the engine.
#44 |
there is absolutly no point in running your fan after the engine is shut down. (talkin street, not drag) Electric fan, mechanical fan, they all shut off when you twist the ignition to off on a factory application becouse the engineers already know this. Every time I say this, I get all kinds of ppl on here saying electric fans stay on, however I think only one odd ball car does that, the rest, shut off with the ignition.
think about it for a second... the fan cools the coolant that is in the radiator, then that coolant goes and cools the engine. So if there is no water pump to push the coolant, then why put such a big load on the battery to cool off coolant, when it can't cool the engine? Engineers may make things hard forr mechanics, but they generally know what they are doing. (with the exception of the ones who did the early 80's escort engine!) |
#45 |
I agree Longhorn man, there is no reason to keep cooling the coolant after the engine is shut off, but I know at least all of the cars I've owned newer than 2000 will keep the fan running. My current car runs HOT and likes to run those fans all the time, even when I'm walking away.
#46 |
I've got a 454 in mine...running a factory style 4-core radiator, original GM big block fan shroud, and a stock 5-blade fan on a thermal fan clutch. In the heat of the summer here in Texas (it gets plenty hot here) running the AC it typically runs around 190-195....if I sit at idle for extended periods it will creep up in the 200-205 range...of course turning the AC off helps.
72' LWB Cheyenne 73' Camaro Z28/RS 70' Chevelle RagTop 00=ss=00 |
#47 |
Hi there I am a new guy long time listener first time poster.
FLEX FANS are dagerous I had one blow I was passing a car and bang a nice dent in my hood sweet Also I have a 454 with 10.2:1 compression and never really had problem I am using every thing that would have come on a stock 396/402. For a couple years I never a fan shroud It was never really a problem. If I would sit traffic on a super hot it mite creep up a bit. My dad also has 402 in his with about 9.5:1 no problem either the cooling system is also stock. Could you be running lean or to much timing.? The stock shroud at the top mounting holes 28 3/4 and I measured my big block 78 burb and it was about 26 you mite be able to make one fit with some fabing I took a picture of my stock shroud and the burbs shroud. I see if I can get the pictures on. |
#48 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
HEY M PLEX CAN i SEE A BIGGER PIC OF UR AVATAR?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#49 |
Here is some pictures to compare stock shrouds
