Old 08-21-2009, 12:18 AM   #26
Deryl
Re: Clear Redwood Planks...for a bed-floor ??
Not a very strong wood for resisting scuffs and abraisions etc, but very pretty
D's 63
Deryl is offline   Reply With Quote
Old 08-21-2009, 07:34 AM   #27
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Originally Posted by padresag View Post
"""These planks are shiplap...so I was planning on getting them in there tite...""""---- you don't want them in there tight as if the pick up moisture they will hump, leave clearance.
Shiplap is meant to go on with clearance so it can expand and contract
ron
thanks man...
Originally Posted by monolith View Post
Save some sawdust and mix it in with your glue to fill the nailholes for an almost invisible repair.
I can't wait to see the finished bed, glad you're gonna give it a shot!
Very good info...I will defiantely do that. What glue should I use....?
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-21-2009, 10:11 AM   #28
502tripower
502tripower's Avatar
Originally Posted by ChiefRocka View Post
Cool man...Defiantely gonna look into that...
Hmm, sound good man, thanks for the info.
Chief, I would not recommend using the ship lap planks. Instead I would machine the planks to the factory specs and use the wear strips. As far as the finish goes I would use Epifanes. Prior to using the Epifanes I would recommend 2-3 coats of a sealer. This will seal the grain of the wood and make the job go much faster alowing you to use less varnish. If you do not use the sealer the wood will soak up the varnish and it will take several coats to build. Even after you think you have a good build of varnish it will later show grain without the sealer. I like Pettit for the sealer. Here are some links. The sealer is the 5th item down. Good luck with your project.
http://www.epifanes.com/products.html
http://www.fisheriessupply.com/onlin...9644FE1007D3F3
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
