08-23-2009, 04:58 PM | #26 |
Re: 68 S/C update.....
The wheel dust covers won't go on all the way. They are hitting the rotor dust cover and won't seat.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-23-2009, 11:17 PM | #27 |
PROJECT 7DEUCE
I love the welds....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-24-2009, 08:23 AM | #28 |
Restoration Virgin!
I say I like old school too!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
08-24-2009, 08:43 AM | #29 |
Update. Tilt column and stereo is in and here's some bling bling. I pulled the carb enclosure off to do some tuning and found some pretty cool bling-bling, , QFT 750 blow thru carb, .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 08-29-2009 at 09:06 AM. |
08-24-2009, 10:37 AM | #30 |
Tot Roddin'
Rob that thing is looking killer!!!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
08-24-2009, 12:15 PM | #31 |
Under Construction
sweet
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
08-24-2009, 06:13 PM | #32 |
sweet truck must be a pita to change jets though...lol but well worth it im shur.
08-24-2009, 06:39 PM | #33 |
VA72C10
Looking for a 67-72 swb or blazer project in or around VA. |
08-29-2009, 07:51 AM | #34 |
subscribed, awesome truck!
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
08-30-2009, 01:51 PM | #35 |
Sorry for being slow with the updates. I've spent the last week cleaning up some odds and ends:
1. tuning the motor - carb and timing (still needs some adjusting) 2. replaced the $29.99 duralast starter , with a high torque one 3. removed the B&M floor shifter since the column shifter is installed 4. Chased down some wiring gremlins....It has an adjustable rheostat to control the electric fan but it has never worked. So I pulled it apart to see what the problem was. The entire circuit was fried, . I think the problem may have been because the electric fan and the high flow holley fuel pump were all connected to the same hot wire coming off of the alternator with no fuses of fusible links in the circuit , So I got everything rewired (the fuel pump had about 5 splices in it....) and connected correctly. I wish people understood how dangerous doing stuff like this was and how easily you can burn your pride and joy down by being careless with wiring. OK, off of my soap box. So I got it running well enough to drive it to the local weekend car show. So me and the wife headed out. About a half a mile from the house it just dies and won't start! Luckily we were able to turn off into an empty neighborhood. After about 2 minutes of going through everything I had done to it, it dawns on me that the fuel pump is not running.....so look underneath and realize that I forgot to crimp the one end of the new wire I had run to the fuel pump, , easy fix and were on our way. It drove and rode quite well on the way over and was getting some curious looks when I pulled into the parking lot . I tried the bad alternator bearing story, but after about 10 minutes I had to open the hood and show em da stuff, . Everyone thought it was pretty cool. It's definitely a sleeper. I think next time I'll go over with the hubcaps on . Here's some picture of the wiring and some new goodies, . .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 08-30-2009 at 01:56 PM. |
08-30-2009, 04:15 PM | #36 |
dazed and confused
man i like the fresh eggs!! i love the sleeper look!
members met: redbaron69, billsbowtie,nc67 |
08-30-2009, 04:44 PM | #37 |
PROJECT 7DEUCE
Very cool glad ya got some of the hazards fixed..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. Last edited by FRENCHBLUE72; 08-30-2009 at 04:44 PM. |
08-30-2009, 06:59 PM | #38 |
Restoration Virgin!
Buddy Buckets and fresh eggs!!!.......that's awesome!!!
08-30-2009, 07:43 PM | #39 |
Tot Roddin'
Nice upgrades there Rob, but when's breakfast?
09-05-2009, 02:43 PM | #40 |
Sunburst C10!!!
great build
Gage 1967 C10 Shortbed Stepside |
09-10-2009, 11:19 AM | #41 |
Quick update, I moved the battery back under the hood and took the battery box out of the bed. I'm currently installing the new 3.73 Auburn posi rearend. Should have pictures later tonight.
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 09-10-2009 at 11:19 AM. |
09-15-2009, 09:15 PM | #42 |
I've got the new rear end installed with the posi and 3.73 gears. And all I can say is uhm............
Here's some pictures of the ZZZZZZZr and the GASSER.... .
09-15-2009, 09:56 PM | #43 |
Restoration Virgin!
I'm definitely a big fan of the sleeper!!!
09-29-2009, 11:06 PM | #44 |
Here's a quick interior update: I got the new seats installed as well as some new 3 pt seatbelts. I still have to install the arm rests, visors and redo the dash pad. I should get that taken care of by th end of the week. What do you think?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 09-30-2009 at 09:57 AM. |
09-29-2009, 11:09 PM | #45 |
motor exploder
I think its pretty damn sweet and I'm jealous!!!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
09-29-2009, 11:20 PM | #46 |
67-72 parts collector,…
Nice.
How many sets of "buddy buckets" do you own? Cool truck!
09-30-2009, 07:26 AM | #47 |
Thanks!
Uhmm, just a couple.....2 for the Burb, 2 for the Crew and 1 for the 68, .
09-30-2009, 09:32 AM | #48 |
PROJECT 7DEUCE
Where did the seat belts come from?
09-30-2009, 09:50 AM | #49 |
They are aftermarket. I got them from someone on the board and I'm not really sure of the brand. I'll see if I can figure it out. They were pretty easy to install and have worked well so far.
R/
09-30-2009, 09:53 AM | #50 |
Under Construction
Rob, did you have the seats redone by an upholstery shop, or did you refoam and cover yourself.....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 09-30-2009 at 09:53 AM. |
