Old 08-26-2009, 08:55 AM   #26
78BO
78BO's Avatar
Re: Lowering info
Originally Posted by 3r!c84 View Post
hey u shoulda did a flip in the back lmao
just messin with yea
Funny
Speaking about drops. If you look at the hitch on the back you can see how the guy that I got it from lowered the hitch by 3in. I forgot about that until yesterday. I was pulling out of the station and there is a big dip. I almost got stuck in the damn driveway lol. I had just idled out of the parking lot and I fill a thud! When to give it gas and the right side wheel just spun. Finally the other side kicked in and got me out. I felt stupid.
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350.
http://www.facebook.com/#/profile.ph...&id=1116781152
78BO is offline   Reply With Quote
Old 08-26-2009, 11:55 AM   #27
shockermotorsports1
shockermotorsports1's Avatar
Re: Lowering info
all you have to do with the flip is relocate the cradel from the top to the bottom it has to be cut off. or find some at the junk yard.
NOS is like viagra. Impressive? Yes, but once you run out your left limp and inadequate.
Racing in a Honda is like beating up a retarded kid, win or lose, you still look bad....
shockermotorsports1 is offline   Reply With Quote
Old 08-26-2009, 12:49 PM   #28
Contagious209
Re: Lowering info
Cradel?
1973 custom delux 20 with 454 project
2000 dodge neon
Contagious209 is offline   Reply With Quote
Old 08-26-2009, 12:56 PM   #29
Driveway Dreams
I have car A.D.D.
Driveway Dreams's Avatar
Re: Lowering info
Contagious, check out this discussion. We got into rear flip kits pretty heavy. Hope it can help. http://67-72chevytrucks.com/vboard/s...d.php?t=358544
-Gerald
Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace.
61 GMC Suburban SOLD
The 86 build thread SOLD
Are you a Colorado member?Click here.
Driveway Dreams is offline   Reply With Quote
Old 08-26-2009, 02:34 PM   #30
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Lowering info
Originally Posted by Contagious209 View Post
When I go to summit I can't seem to find a flip kit or lowering springs for the front. Another question is if I buy for a 1/2 ton would it work for my 3/4 ton? Cus if I can find a flip kit for my truck I'll buy it and same for springs Cus I could use a drop
for the front you can use half ton coils because I have a set of stock coils out of half ton and 3/4 ton and there the same size
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 08-26-2009, 03:14 PM   #31
shockermotorsports1
Re: Lowering info
the cradel secures the axel to the leaf with a dow din on the logest leaf.
Old 08-26-2009, 07:14 PM   #32
Contagious209
Re: Lowering info
This should work fine right
http://www.summitracing.com/parts/MMC-33152/
n these shackles
http://cgi.ebay.com/ebaymotors/1973-...QQcmdZViewItem
2000 dodge neon
Old 08-26-2009, 07:27 PM   #33
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Lowering info
You don't need a c-notch with JUST a 2" shackle.
Look around on the board,... and see what everyone else is doing to lower their trucks. Find a drop you like and go for that. 2 inch rear drop isn't much.
Keith
Convert to disc brakes.
Old 08-26-2009, 07:37 PM   #34
Contagious209
Re: Lowering info
Well I was on summit and that's all that showed up for my truck for a flip kit
2000 dodge neon
Old 08-26-2009, 08:01 PM   #35
lolife99
lolife99's Avatar
Re: Lowering info
Give Sport Truck Direct a call. I believe their c30 parts will work on your c20.
http://www.sporttruckdirect.com/rear_kits.html
Keith
Old 08-26-2009, 08:15 PM   #36
Contagious209
Re: Lowering info
I will thanx
2000 dodge neon
Old 08-26-2009, 10:20 PM   #37
shockermotorsports1
Re: Lowering info
check these out
http://www.stylintrucks.com/part.asp...9&partid=12901
http://www.streetpros.com/product_in...ucts_id/38741/
Old 08-27-2009, 12:01 PM   #38
Contagious209
Re: Lowering info
Would both work fine ? I know the second one comes with ubolts and the first one doesn't. If they work I'm getting ready to order. Most likely I would go with the second one since it comes with u bolts
2000 dodge neon
Old 08-27-2009, 03:32 PM   #39
3r!c84
Badass
3r!c84's Avatar
Re: Lowering info
take a look here
http://www.summitracing.com/search/?...JM%20c10&dds=1
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-27-2009, 03:38 PM   #40
Contagious209
Re: Lowering info
Are those good for my 3/4 ton?
2000 dodge neon
Old 08-27-2009, 03:45 PM   #41
3r!c84
Badass
3r!c84's Avatar
Re: Lowering info
you got me there.i dont know.
it dont realy specify. they dont realy make lowering kits for 3/4 trucks.
its mostly all 1/2.
what rear end you got 12 bolt?
-00 Saturn 5spd
1/4:13:90
Old 08-27-2009, 04:56 PM   #42
shockermotorsports1
Re: Lowering info
the second kit is spec for the 3/4 ton. they are well worth the 90 bucks. then on the front cut 3/4 coil off the spring and get some shims and you will be good to go. You have to shim the upper A arm or it will have a ton of camber
Old 08-27-2009, 07:15 PM   #43
Contagious209
Re: Lowering info
Thanks guys u all been good help
2000 dodge neon
