Old 08-23-2009, 08:17 PM   #26
otsenre
otsenre's Avatar
Re: anyone ever built a trailor out of
Originally Posted by Skirkpat View Post
we always used them for firewood, cut wood in the pasture and then leave it in the trailer by the house, saves alot of uloading/loading, my buddy has two burn barrels in one, pulls it up to the house, then out back to burn when they are full.
Here is mine, heavy duty Name:  IMG_1108.jpg
otsenre is offline   Reply With Quote
Old 08-23-2009, 10:39 PM   #27
eke82
my dad and i have built probably 18 trailers over the years. We take pull the 2 sides together and use a 2-1/2 in square tube in the center welded to the rear cab mount with a two inch coupler on the front it helps make it really strong so nothing flexes. we have also have taken the front spindles and had a tube welded between them and used that has a rear axle
eke82 is offline   Reply With Quote
Old 08-24-2009, 01:25 AM   #28
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I didn't build it, but here is mine (1/2-ton with leaf springs). It tows nicely but I wish it was a 3/4-ton. I think the tongue would be nicer if it had been brought together just ahead of the cab mounts. It has been beat to h*ll by previous owners (I bought it at the metal scrap yard).
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 08-29-2009, 12:48 PM   #29
capev86
if you have a short bed truck, a matching long bed trailer would look sweet at cars shows.
i want to do that with my 87 ram 50 (mitsubishi). my grandfather had an 87 long bed before the short bed that i now have. i have my 72 burb for all the serious towing needs, but i want to coat the truck (and possible trailer) up with poly bed liner and used it for hauling snowmobiles in the winter.
capev86 is offline   Reply With Quote
Old 08-29-2009, 03:06 PM   #30
jerry moss
Born Psycho
jerry moss's Avatar
here's mine, made from an original paint 70 longbed. i used an HO52 axle without the 3rd member and welded a flat plate over the hole to keep out dirt and water, sawed off the axle shafts, packed the bearings with boat grease, took the hub/drum assemblies to work and chucked them up on the brake lathe and cut the drums off to lighten it up, also removed all the brake components including the backing plates. it has 3/4 ton leaf springs and i've hauled many loads that were close to 2 tons with no problems at all. it also has an extra long tounge so backing is a breeze and i added a diamond plate toolbox and a lumber rack after this pic was taken
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is online now   Reply With Quote
Old 08-31-2009, 01:05 AM   #31
BGRAFX
What's the best place to cut the frame? I would like to make a matching truck bed 73-87 for my 91suburban....
BGRAFX is offline   Reply With Quote
