08-24-2009, 12:27 AM | #26 | |
I have car A.D.D.
Re: What did you get done 8/23/2009 edition
I did my normal, yard work, hang out around the house and enjoy my one day weekend. Dang! I hate the care sales business schedule. Oh, I did find a front clip that I am thinking about for my truck.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
08-24-2009, 12:33 AM | #27 |
6.0 powered square
went to two car shows and sanded on my sister car so it can get painted soon
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
08-24-2009, 01:03 AM | #28 |
In the Forgotten far North.
Finished installing my stereo (AGAIN!) in my Suburban. You can see it here.......
Double DIN install
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
08-24-2009, 09:52 AM | #29 |
a fool with no money
busy weekend... installed motor friday night
had some interference with the pass side header, so I beated on a freshly powder coated oil pan with a rubber mallet to get clearance used a 2x4 as a measuring block for a 1" spacer and N2o plate to mock up my fuel lines installed the dist. and cut new plug wires to length... worked on my console... I eventually plan on swapping out my interior from brown to black & grey
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ |
08-24-2009, 09:55 AM | #30 |
N2billet strikes again . . ......
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-24-2009 at 09:56 AM. |
08-24-2009, 10:02 AM | #31 | |
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ Last edited by Moostifer; 08-24-2009 at 10:05 AM. |
08-24-2009, 12:20 PM | #32 |
yeller
Moostifier, engine looks great. LOSE that air cleaner ASAP though. They look like crap, are restrictive, and more importantly, are prone to causing engine fires.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
08-24-2009, 12:28 PM | #33 | |
it's just there to keep the dirt dobbers out was a throw-in freebie on some wheelin/dealin. I'm making a custom one
08-24-2009, 01:03 PM | #34 |
Low & Fast!
Thanks guys! I just happy that I had some free time to drive it. And Ken sorry about the blow out I did that back in the spring 2 time, but I tell you what I did is pull your back wheel over a curb to get it off the ground then you can change it.
08-24-2009, 01:40 PM | #35 |
Happy to be here
08-24-2009, 01:41 PM | #36 |
Happy to be here
Hmmm, not a bad idea. Lets hope there is no "next time" but if there is...
08-24-2009, 03:53 PM | #37 |
Still plays with trucks
08-24-2009, 04:03 PM | #38 |
Fixed a pesky master cylinder that was sucking air and pressure bled the system. It's nice to stop when you push on the brake pedal.
Put a CD player into the stock stereo opening without using an adapter. Put a pair of speakers into the doors. Built a pair of cab corner 6x9 panels. Still need to make the curved top section and seal the enclosure. Swapped out the plastic window crank handles for a set of early GM metal handles. |
08-24-2009, 04:12 PM | #39 |
installed a new prop. valve and last brake line...
getting ready to start on this...
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
08-24-2009, 07:47 PM | #40 |
its just $$$$$
08-24-2009, 08:03 PM | #41 |
I was dang close then wasn't I..... . He can be just as bad.
08-24-2009, 08:04 PM | #42 |
Where did the prop valve come from? Me likey.....
08-24-2009, 08:33 PM | #43 |
Happy to be here
08-24-2009, 10:35 PM | #44 |
08-24-2009, 11:32 PM | #45 |
Nothing truck related.
I pulled the doors off my old cab the prior weekend and picked up my new cab, too. Also got the title to my new cab transferred into my name. Hoping to go all the way to the frame this weekend if everything allows. |
08-25-2009, 12:38 AM | #46 | |
Garage wrench
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
08-25-2009, 06:55 PM | #47 | |
I got my brackets from here: http://greatlakeoffroad.com I was happy with them and the price was good too. I think I paid 47 shipped through pirate4x4.com Mike |
08-25-2009, 07:32 PM | #48 |
Rocker and cab corner! One side down one to go
***My 84 short bed build up***** http://67-72chevytrucks.com/vboard/s...68#post3481968 |
08-26-2009, 11:21 AM | #49 | |
08-26-2009, 05:05 PM | #50 |
