Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-01-2009, 03:28 PM   #26
noonzor
Re: LS1 Build Questions
Originally Posted by Super73 View Post
I can't say I have seen too many 400+rwhp 5.3/80E/12bolt NA setups. My little alum 5.7 was making 428rwhp through an 80E/12bolt with a factory LS6 intake and stock ported TB. The bore on a 5.3 kills them NA. That's also the killer for the 5.7 vs a 6.0 or even 6.2.
The larger bore allows some unshrowding of the intake valve allowing better flow. Look at any head that has flow data for both a 3.9 and 4.0 bore and you'll see the numbers go up quite a bit. The larger bore is always going to be easier to make power with if staying NA.
If I was building a NA motor or even N20 motor for a 200-250hit, from scratch on a semi budget, I'd go find a LS3 block, shove a set of diamond pistons in it with the factory crank. Pick up a set of used ported heads and spec a cam based on that. Sure you might be in the longblock at about $3,500-4,000 but you'll also be 70lbs lighter and where better can you have it than right over the front end. You'll also be ableto hit it hard with a 250 hit.
Lack of weight over the front makes large differences when trying to make something work.
....so what your saying is....? haha sorry im just not sure im understanding. i drank a lot of beer last nite my brain may just not be computing properly today sorry. im not totally interested in nitrous, if im going power-adder itll be some sort of forced induction system only.
noonzor is offline   Reply With Quote
Old 09-01-2009, 04:41 PM   #27
swb85
On a budget like Fred Sanford
swb85's Avatar
He's saying that for a non FI application you want the bigger bore to unshroud the valves and aid cylinder fill. The 5.3/5.7 LS motors both have smaller than 4" bores while 6.0/6.2 motors have bores of 4" and 4.06" respectively.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 09-01-2009, 04:44 PM   #28
1FAST68
I would do a 6.0L, I got a 6.0L rebuilt it back with arp rod and head bolts, used a set of L92 heads and a comp cam. Runs on pump gas and went 11.80's -12.00 in my 68 truck.
1FAST68 is offline   Reply With Quote
Old 09-01-2009, 06:35 PM   #29
noonzor
ahh ok i see i see, yeah i didnt now that but i was looking more towards the 6.0L, originally because its a 6.0 and not a 5.3, but that info helps!! thanks for the tips guys i really appreciate it.
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
Old 09-01-2009, 10:16 PM   #30
Super73
Super73's Avatar
I also know where there is a 408 stroker Iron block for sale. Ported heads, 9.5-1 cr and ready for boost. Comes with almost everything to be turn key.. I was originally thinking of selling my motor and going with it, but decided against it..
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-02-2009, 10:56 AM   #31
Alex1
Alex1's Avatar
Originally Posted by noonzor View Post
any pics of the set-up so far?
I may have some pics of the pipes, but right now I'm working on cleaning up the truck.
Alex1 is offline   Reply With Quote
Old 09-02-2009, 12:41 PM   #32
noonzor
awesome, you got a build thread for it by chance?
Old 09-02-2009, 12:55 PM   #33
Alex1
Alex1's Avatar
Not yet! LOL. Once I REALLY start putting stuff together I'll set something up.
Billet impeller turbos are pricey - certainly if you need to buy two ! LOL
Old 09-02-2009, 12:59 PM   #34
noonzor
haha i bet, nice lookin pipes man! do them yourself or sourced out?
Old 09-02-2009, 01:18 PM   #35
Alex1
Alex1's Avatar
We started to build mild steel ones and then I broke down and bought some 304ss and sourced it out to a guy in the States. I paid like $400.00 to weld 'em up. Pipes, flanges and collectors were like 600 or so and the V bands were a couple hundred bux.
I've got 4340 crank rods, block, dart heads solid roller etc. waiting ,but it's time for the body work to start.
Old 09-02-2009, 09:46 PM   #36
Wild83C10
Wild83C10's Avatar
Wow, those headers are pricy. But that is the going price for SS turbo headers. Did you check our Stainless Works?
What turbos are you running? Why billet?
Good old BW turbo will do the trick. Mine was $400.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 09-03-2009, 08:46 AM   #37
Alex1
Alex1's Avatar
I had a BW S480 with race cover - ended up selling it because for my 468 it's not optimum. I'm looking at the Precision turbos 72 -76mm with billet impellers, or a single 94-106mm with billet impeller. The billet impellers make more power, there a bit more agressive and have newer technology.
I think the 2" SS was $15 or so a J bend. Flanges were expensive and the colletors were as well
I'm looking to make 800rwhp.
Old 09-03-2009, 09:10 AM   #38
Shon
I love the LS based series of engines. Let me know what you need, I can get most anything you need or point you in the right direction.
I use Advanced Induction for CNC heads and custom cams and I carry a full line of Comp Cams/etc.
It may not be on my website but I can get it!!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 09-07-2009, 11:51 AM   #39
noonzor
sweeeeet, thanks man!!!!
Old 09-16-2009, 12:15 AM   #40
noonzor
still know where that motor resides by chance?
