09-05-2009, 01:59 AM | #26 |
Re: Here's the scoop, see......
Maybe a pinstripe of the same color as your truck would look nice till you can paint it.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
09-05-2009, 10:21 AM | #27 |
UCA63
That looks good
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
09-05-2009, 03:16 PM | #28 |
Gorgeous ride.
-W |
09-05-2009, 03:30 PM | #29 |
66 C20 Long Step
Looks great!!
09-05-2009, 05:48 PM | #30 |
#16876
I'll be honest. I'm mixed on it. The shape matches the hoods lines totally. Great choice. The color is great too. My mixed feeling is seeing the hood scoop first the the V-6 emblem. No offense, but that kinda let the wind out of the sail for me. I hope you are not offended. Your truck is awsome. You're miles ahead of me buddy.
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
09-05-2009, 06:52 PM | #31 |
Cort, I sent you a PM.
Jake
http://s1299.photobucket.com/user/jb...23904108567829 |
09-05-2009, 11:03 PM | #32 | |
Just here to tinker
I appreciate the criticism, we all need it to keep us in check!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
09-05-2009, 11:04 PM | #33 |
Just here to tinker
Hey Jake, I didn't get one in my inbox.......????
09-13-2009, 07:04 PM | #34 |
Just here to tinker
OK, here is the set-up thus far. I'm trying to figure out a way to make some sort of assembly that will seal to the hood, but right now I need it driveable because I am taking it to Cali in a couple weeks.
I ordered the filter discs for it but right now I just have mesh screen. By the way, when you hear carbs suck in air from the scoop, it is just about the most awesome sound you can get!!
09-13-2009, 07:22 PM | #35 |
Registered Loser
You could make a pan with 2 holes that sits on the carbs (where the air cleaner gasket goes) and put a foam or rubber seal around the edge. When you put the air cleaners on it would hold the pan on.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
09-13-2009, 08:25 PM | #36 |
Just here to tinker
I would but the 97's don't have a gasket area. Those early carbs are 2 5/8" neck and the air cleaners were a clamp on type unit.
The biggest issue with making a plate is that the top of the carb is exactly flush with the hood, as you can see in the pic above. So I may not be able to make any type of seal unless some one has some ideas??
09-13-2009, 08:25 PM | #37 |
Torn between 66 and 78
Looks very nice.
What kind of tires are you running there? |
09-13-2009, 08:32 PM | #38 |
Cort, in this picture, at the bottom of the hose clamp. There seems to be a lip. Is there? And is it substantial enough to maybe rest a plate on top of it?
09-13-2009, 09:12 PM | #39 |
Senior Enthusiast
Just curious, if the holes in the hood were bigger, could you install the chrome filters and still have clearance to close the hood? Perhaps with a different style air cleaners? I really like the scoop cosmetically, but didn't realize it was functional to feed the carbs.
My concern being if the hood is sealed to the carbs, they are going to get drowned in the rainy season. I had a louvered hood on my last car and had to be very selective about air cleaners so my carb didn't get soaked. I also covered the engine with a plastic trash bag every time I washed the car for the same reason. I would be inclined to open the inside of the hood up as large as the scoop, install filters on the carbs and allow the engine to draw from the scoop or from within the engine compartment. I can't find the link, but I remember seeing a 60's muscle car where the owner built a removable pan that held the air filter above (inside the scoop) and rubber seals below with drainage built in. It attached directly to the bottom of the hood. The carbs had nothing on top until the hood was closed sealing the system. It might not be all that difficult to dream up something along those lines. |
09-13-2009, 09:14 PM | #40 |
Just here to tinker
You can see in this photo what I have to work with:
And the tires are Coker Classics 7.10-15's
09-13-2009, 09:20 PM | #41 |
If you had something like this made, do you think it would work? Maybe with a couple of set screws maybe? May be able to rest on the lip.
09-13-2009, 10:43 PM | #42 |
Just here to tinker
Hey that's pretty damn good! I was thinking something similar, the filter disc could just lay down in there....
I have some velocity stacks, maybe I'll just cut those down to where they don't hit the scoop when the hood is shut.
09-13-2009, 11:14 PM | #43 |
chevy only
killer truck!!!
CHEVY ONLY... Nothin Else ! |
09-13-2009, 11:25 PM | #44 |
Cort, I love the truck! That's pretty much exactly how I envisioned my truck looking when I'm finished. Solid black stock rims with chrome lugnuts, white walls, turquoise and white paint. Perfect.
Can you tell me exactly what color that is and where you got it?
www.vancerutherford.com |
09-13-2009, 11:31 PM | #45 |
Resistance is Futile
Maybe ABS plumbing fittings? Pipe? I also liked markeb01's idea of the assembly on the hood....do you still have your extra hood to do some exploratory surgery?
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
09-14-2009, 12:22 AM | #46 | |
Just here to tinker
09-14-2009, 12:24 AM | #47 |
Just here to tinker
Yeah I still have the other '60 hood. Do you mean using pipe to go around the carb tops?
09-14-2009, 12:33 AM | #48 |
Just here to tinker
[QUOTE= It attached directly to the bottom of the hood. The carbs had nothing on top until the hood was closed sealing the system. It might not be all that difficult to dream up something along those lines.[/QUOTE]
I missed this one somehow........yeah, maybe even using the gas tank to cab gasket as a seal from the hood to the carbs? That might work out pretty good. I've got to do some playin around....
09-25-2009, 07:40 PM | #49 |
Just here to tinker
OK, I have decided for now just to have the holes in the hood and not make a sealed set-up. So here are some pics of the filter discs (Nevermind they are taped on for now!) I am running and a quick video of how the carbs sound through the scoop!
Also, a pic with the camper (Resto in progress) Now the goods:
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 Last edited by Corts60; 09-25-2009 at 07:41 PM. |
09-25-2009, 07:48 PM | #50 |
Senior Enthusiast
Sounds a lot like my old 54 Chevy sedan in high school. I always left the air cleaner off as I loved the sound effect, especially when pulling a hill.
